Old 02-01-2022, 01:19 AM   #1
Sur
Sur's Avatar
Drives: GEN-1-86-MT-FI / 2022 KTM RC 390
Auto window drop
Is there anyway to disable the window from auto rolling down when opening the door? This is my second tint job and when the window does its auto drop when the door opens it’s causing issues with the tint. The shop will redo it with no issues but it is going to keep happening. Besides not having tint, I was wondering what can be done about stopping the window from its auto drop, if even possible. Anyone else having this issue or should I use a different shop. Also, the tint job is from the inside and it looks great besides the fact that I can see it’s going to lift again soon.
Thanks in advance.
Sur is offline   Reply With Quote
Old 02-01-2022, 07:02 AM   #2
Windycitystig
Drives:
Get a second opinion for another shop. I’ve had window tint without the same issue.
Windycitystig is offline   Reply With Quote
Old 02-01-2022, 07:46 AM   #3
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Get a tint shop that knows how to do frameless windows. I've had 2 BRZs tinted with no issues with the windows.
dragoontwo is offline   Reply With Quote
Old 02-01-2022, 07:55 AM   #4
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
same no issue with my tint for owning 9 years of my 2013 BRZ
Old 02-01-2022, 07:59 AM   #5
I smoke so my window goes up and down many more times than norm. The only issue I had with tint on either the FRS or 86 was a small tear at the bottom that had nothing to do with the auto up down.
I would much prefer to have my tint risked (not that I have) than my window shatter from being fully up and closed against the seal all the time.
Old 02-01-2022, 08:29 AM   #6
Grady
Grady's Avatar
Pull window fuse.
Grady is online now   Reply With Quote
Old 02-01-2022, 10:33 AM   #7
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Auto window drop
The window indexing feature won’t mess with quality tint that’s installed correctly. I’ve had 5 frameless window cars with indexing side windows tinted by 5 different shops and different tints (3M, pinnacle, and expel). None of them caused problems with the tint.
As Tcoat said, the indexing isn’t for show.
You’re being fed BS by the installer or they’re really bad at it.
Old 02-01-2022, 12:45 PM   #8
alex87f
Meow
alex87f's Avatar
Drives: Focus ST mk4
Having been in a scenario where the auto-drop wasn't working (I think it was dead battery), I wouldn't want that on a daily basis.
There's a high risk the window will interfere with the rain guard on the door frame. Some careful manipulation will allow you to close the door with the window all the way up, but on a daily basis this would be bound to break sooner or later (and probably sooner).
alex87f is offline   Reply With Quote
Old 02-01-2022, 10:12 PM   #9
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
Definitely installer error. It sounds like they are not aligning the tint far enough under the weather stripping to clear it.
2020BRZtS is offline   Reply With Quote
Old 02-07-2022, 03:36 PM   #10
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
Installer doesn't know they need to leave a gap from the top of the window edge to avoid having the tint stripped by the weather stripping (or they're not leaving enough of a gap). I would ask for a refund and go to another installer: who knows what else they're not paying enough attention to.
CrowsFeast is offline   Reply With Quote
Old 02-07-2022, 05:40 PM   #11
dragoontwo
dragoontwo's Avatar
My tint goes to the edge. No problems here.
Old 02-07-2022, 06:02 PM   #12
Yoshoobaroo
TRACKBREAD
Same here
Old 02-07-2022, 07:41 PM   #13
Originally Posted by Yoshoobaroo View Post
Same here
Old 02-08-2022, 07:47 AM   #14
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Same
Any way to change window auto-up/down? Willy Smith BRZ First-Gen (2012+) — General Topics 15 07-02-2020 10:51 AM
Auto window? gt3400 Cosmetic Modification (Interior/Exterior/Lighting) 7 03-05-2014 03:44 PM
Power window auto drop fault ? Suberman CANADA 2 11-09-2013 07:14 PM
Window auto close module..? luv85 Scion FR-S / Toyota 86 GT86 General Forum 1 11-18-2012 01:05 PM
Auto up and down window Issues? CzRceCar Issues | Warranty | Recalls / TSB 3 08-07-2012 07:44 PM
