Old 02-16-2020, 07:50 PM   #1
Willy Smith
Any way to change window auto-up/down?
Any way I can stop the windows from rolling down and up slightly when the door's opened / closed?
I know this is a nifty convenience feature.
The driver's side window grabs the door seal and wraps it up near the top. Silicone grease is temporary and messy.
The passenger's side sounds like it's crunching glass when it gets to the top, despite my best efforts to keep it spotless.
And, I am in no hurry to replace the power door parts. Mostly 'cause plastic trim fasteners love to fall apart.
So, any way to change the setting for this?
Many thanks;
Alan
P.S., meant to post this in the main forum, but can't seem to move it. Any advisement welcome.
Willy Smith is offline   Reply With Quote
Old 02-16-2020, 11:30 PM   #2
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Tape the little black button sensor on the door jamb down.
The Following 3 Users Say Thank You to Kiske For This Useful Post:
DarkPira7e (02-17-2020), p1l0t (02-18-2020), Willy Smith (02-16-2020)
Old 02-16-2020, 11:55 PM   #3
Willy Smith
Thanks!
I'm not above that. Does that switch go anywhere else? I'll give it a shot and report back. Appreciated.
Old 02-17-2020, 12:35 AM   #4
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
It is you door ajar switch so things like door chimes and the auto (when opening the door) interior lights might not function.
The Following User Says Thank You to Kiske For This Useful Post:
Willy Smith (02-17-2020)
Old 02-17-2020, 08:49 AM   #5
gravitylover
If it doesn't move down a bit when you open the door the glass has a very high chance of breaking and if it doesn't go back up it will leak (air and water) and be a bigger pain in the ass than having to clean the edge occasionally. The frameless windows on our OB don't do this and it has caused problems. Consider that 1/2" of movement a good thing.
The Following 4 Users Say Thank You to gravitylover For This Useful Post:
JesseG (07-28-2020), p1l0t (02-18-2020), Tcoat (02-17-2020), Willy Smith (02-17-2020)
Old 02-17-2020, 09:47 AM   #6
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
the height the windows go is adjustable by an adjuster in the door I believe. At least I saw that somewhere.
The Following 2 Users Say Thank You to why? For This Useful Post:
JesseG (07-28-2020), Willy Smith (02-17-2020)
Old 02-17-2020, 10:10 AM   #7
ls1ac
ls1ac's Avatar
There are several dry lubricants that you could try. These will not attract dirt. Often sold for aluminum slides.
The Following 2 Users Say Thank You to ls1ac For This Useful Post:
Old 02-17-2020, 01:22 PM   #8
gravitylover
Be careful if you use a lube on the rubber, some act as dessicants on materials other than metals and will ruin it. It can also cause air leaks in the gaps and the wind noise will certainly be more annoying than a strip of dirty glass at the edge of the window. Just resign yourself to taking 30 seconds out of your life every two weeks or so and wipe the top of the window off.
The Following 3 Users Say Thank You to gravitylover For This Useful Post:
JesseG (07-28-2020), p1l0t (02-18-2020), Willy Smith (03-08-2020)
Old 02-27-2020, 02:13 AM   #9
fistpoint
Drives: Supercharged Golf Cart
I got used to just leaving the window cracked just enough to not activate it. Unless it rains more than lightly, there is no water that enters. The motor gets used less too.
fistpoint is offline   Reply With Quote
The Following User Says Thank You to fistpoint For This Useful Post:
Old 06-23-2020, 11:44 PM   #10
e30cabrio
e30cabrio's Avatar
Drives: 2017 86
I just got a low mile 2017 86 and the interior light does not come on/turn off when the door is opened/closed.
It is a CPO from Toyota and I brought it back & they blamed the OEM Subaru Homelink/compass mirror I installed using the OEM harness into the OEM harness which is otherwise untouched & more importantly they ignored that it was happening before I installed the mirror.
Last night I was sitting in the car with the door open in my garage and the window jittered up & down by its self (made me jump) and the light came on!
I tried all the window resets I could find with no resolution any input would be greatly appreciated.
e30cabrio is offline   Reply With Quote
Old 06-24-2020, 12:18 AM   #11
soundman98
ProCrastinationConsultant
soundman98's Avatar
either a bad door switch, or you have the light function selector switch to the 'off' position.
Old 06-24-2020, 07:48 AM   #12
e30cabrio
e30cabrio's Avatar
Drives: 2017 86
It is happening on both doors & of course, this is when the switch is set to door.
The windows jitter up/down sporadically, both sides when open I then found after trying to figure it out.
I ran Techstream and the system checks good and I can toggle the light on & off with Techstream.
Also, the light turns on when I shut the car off and goes off a few seconds after closing the door.
Old 07-02-2020, 09:45 AM   #13
reebis
reebis's Avatar
Drives: 2020 STI Limited
Most likely your door jam switches are toasted. I had the same issue on my passenger side where the window would constantly move u[ and down when the door was open. To test, open the door and then wiggle and depress the door switch. If the window moves up and down based on the movement you put into the switch, then it's time for a new one. I had mine replaced under warranty.
FYI...I had to show the issue to the Tech twice before he realized what was going on. Initially they told me everything checked out fine (assuming they hooked it up to TechStream or whatever and no codes came back), so I had to jiggle the switch for them again. The 2nd time they got it and replaced the switch.
reebis is offline   Reply With Quote
The Following 2 Users Say Thank You to reebis For This Useful Post:
e30cabrio (07-02-2020), JesseG (07-28-2020)
Old 07-02-2020, 09:55 AM   #14
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
FYI, the later models (2014 and up I think) changed the door indexing programming to cut the travel in half.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
JesseG (07-28-2020)
Passenger's Auto Window Scroll Bonburner Issues | Warranty | Recalls / TSB 204 04-17-2018 07:34 PM
DIY - Cancel auto up/down window for winter Rayme DIY (Do-It-Yourself) Guides 28 04-18-2014 11:23 PM
Auto window? gt3400 Cosmetic Modification (Interior/Exterior/Lighting) 7 03-05-2014 03:44 PM
Stop window auto scroll Rumbaar Cosmetic Modification (Interior/Exterior/Lighting) 10 08-27-2013 06:44 PM
Auto up and down window Issues? CzRceCar Issues | Warranty | Recalls / TSB 3 08-07-2012 07:44 PM
