| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Clutch replacement
What is a reasonable price for a clutch replacement on a 2013 brz. Just got quoted $3,300.
Drives: 2022 BRZ
What.
Did inflation hit that high already? Should be 4-6 hours to do at a shop + ~$450 for Exedy OEM Clutch and Flywheel. Unless your shop is charging $500/hour you're getting ripped off massively. |
Drives: 2014 Scion FRS
If you want to save some money and do it yourself, you can use this guide:
Drives: None
A friend that is a Honda tech offered to do mine on the side for $300 in labor, which I thought was pretty reasonable, however I ended up doing it myself since I found some free time. He said he can get one done in a couple of hours, this was my second time around in the span of 3 weeks and it took about five hours on the floor in the garage.
Obviously you can probably beat what I spent on parts: $33 for OEM clutch release fork $35 for OEM throwout bearing and all three clutch fork clips $29 for Verus clutch pivot $279 for Exedy OEM clutch / pressure plate / throwout bearing / pilot bearing kit (didn't use the throwout bearing since it clearly isn't the same as the OEM updated one) $25 for 2l Motul gear oil (had another left over quart from the other car) About $400 in parts and $300 in labor is about as cheap as it gets if you can't do it yourself. If the throwout bearing was seized for a while you might end up needing a $75 transmission "Front Bearing Retainer Cover", otherwise known as the thing that the throwout bearing rides on. If the car has higher mileage or the flywheel is torched it'd be another $175 for that.
not playing cards
I think for Brits at least, it's called a quill.
Drives: 2013 FR-S Series 10
I spent 700$ a few years back. I know inflation is koo-koo but your quote is way out of line.
3k is one of those quotes where the mechanic doesn't want to deal with it, but will, at a crazy price. Or his daughter just got braces or something, yeesh.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
TRACKBREAD
I had it done at the dealer in 2019 for <1400$ with a few extras.
Stock clutch, new flywheel, new TOB, new tranny fluid and new diff fluid. |
| DIY Clutch Replacement | Supermassive | DIY (Do-It-Yourself) Guides | 217 | 08-27-2023 12:35 PM |
| OEM-like clutch replacement | B-R-Z | Engine, Exhaust, Transmission | 31 | 02-22-2020 04:27 PM |
| Is $1600 for a clutch replacement too much? | Rohint75 | Engine, Exhaust, Transmission | 33 | 08-22-2018 01:05 PM |
| Clutch replacement | pinetree | Engine, Exhaust, Transmission | 21 | 05-03-2017 08:48 AM |
| Clutch replacement | Thatguyjeremy | Engine, Exhaust, Transmission | 0 | 02-28-2015 04:22 AM |
