Old 01-19-2022, 04:49 PM   #1
demasrv
demasrv's Avatar
Drives: 2013 Rally Blue BRZ
New short block, should I use break-in oil?
I'll have my car started up for the first time with a new short block this weekend. I've done the work myself, but I can't decided if I need to use break-in oil for the first ~100 miles before I go to the usual 0w-20. Normally I'd just follow the manual, but given I'm doing the new (OEM) short block myself there's no factory testing or anything done. Also the IAG short blocks have a break-in procedure that requires break-in oil.
Thoughts?
demasrv is offline   Reply With Quote
Old 01-19-2022, 05:32 PM   #2
TommyW
TommyW's Avatar
Drives: '13 Whiteout
I have IAG and yes break in oil is the best for a new engine. I believe I used the Motul. Changed at 50, 500 and at 1,500 went to non break in
Break in oil, new short block demasrv Issues | Warranty | Recalls / TSB 4 01-29-2022 10:26 AM
Staged short block or upgrading current block internals? (Old tale) BrahmaBull1990 Engine, Exhaust, Transmission 17 08-13-2021 03:12 AM
Break in for new short block? ECU? Ashikabi Engine, Exhaust, Transmission 9 07-05-2016 05:47 PM
WTB: FA20 Long Block/Short Block blown/running The Racers Line Engine, Exhaust, Bolt-Ons 7 07-29-2014 01:26 AM
WTB: FA20 Short Block or Blown Long Block The Racers Line Want-To-Buy Requests 1 06-29-2014 05:21 PM
