Old 07-05-2016, 02:27 PM   #1
Ashikabi
Ashikabi's Avatar
Break in for new short block? ECU?
My short block and ECU are being replaced under warranty. Should I be going easy on it per the manual? Does that only apply to new cars presumably broken in from the factory and not my brand new short block? Or should I abuse it to"teach" the ECU to run more aggressive trims during that critical <100 mile period when it will permanently save driving habit information with it's "handshake" with the engine? I'll be tuning on e85/flex fuel after I'm confident the dealership didn't fuck anything up
Old 07-05-2016, 02:45 PM   #2
New short block? Break it in like a new car.
Old 07-05-2016, 02:48 PM   #3
Ashikabi
Ashikabi's Avatar
So the toyobaru manuals' recommendation?
Old 07-05-2016, 02:57 PM   #4
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
What happened to the first engine?
justatroll is offline   Reply With Quote
Old 07-05-2016, 03:04 PM   #5
Ashikabi
Ashikabi's Avatar
Spun a bearing> contaminated oil> clogged cam control valves> somehow damaged the cam gear???> ecu stuck thinking the cams don't have enough oil pressure even though they do. There weren't any noticeable symptoms indicating the engine was damaged except I noticed a ticking/tapping noise. But these cars make all kinds of noises so I don't know when it happened. I've never over revved or boosted so I blame mechanical failure. Apparently quite a few 2013s spun bearings according to Tcoat
Old 07-05-2016, 03:15 PM   #6
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Depends on what engine break in philosophy you subscribe to.
Personally, I subscribe to break in oil and gentle driving up to temp, then lots of 100% load varied driving for 100 miles or so, changing the oil, THEN following OEM break in procedures.
Gotta seat those rings!
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 07-05-2016, 03:21 PM   #7
Ashikabi
Ashikabi's Avatar
This is why I'm asking. That the opposite of what the manual recommends. My tuner says to follow the manual.
Old 07-05-2016, 03:32 PM   #8
JazzleSAURUS
My opinion is that if you trust your car to your tuner, follow their advise. If he's the guy tuning it, and it's his arse on the line if something goes wrong, then you can count on him being confident in that.
I've got 80k on the built motor on my forester by giving it as close to 100% load as I could give it, as long as I could give it with BP break in oil.
Old 07-05-2016, 03:39 PM   #9
Ashikabi
Ashikabi's Avatar
Well I guess it's not a question of if the manual's break in will work, it's if a different approach is "better"
Old 07-05-2016, 05:47 PM   #10
Lantana frs
Drives: 13 frs red
My 13frs has 3k on entire new motor. Original spun bearing and was replaced with a short block which failed due to bad assembly. Toyota stood by it though. New motor has much less valvetrain noise than the original.
Lantana frs is offline   Reply With Quote
WTB: Used Short or Long Block NotSoJDM Want-To-Buy Requests 2 12-27-2017 11:51 PM
FA short block xwd Want-To-Buy Requests 0 03-07-2015 11:42 AM
WTB: FA20 Long Block/Short Block blown/running The Racers Line Engine, Exhaust, Bolt-Ons 7 07-29-2014 01:26 AM
WTB: FA20 Short Block or Blown Long Block The Racers Line Want-To-Buy Requests 1 06-29-2014 05:21 PM
WTB: short block or long block DOTman05 Engine, Exhaust, Bolt-Ons 2 07-14-2013 06:48 AM
