Old 01-19-2022, 07:12 AM   #1
Purist
Purist's Avatar
Drives: Subaru BRZ
Hesitation on no load throttle opening
Hi all, I have a Ford courier (not sure if or what this is called overseas). It has EFI and it has the briefest 'stutter' when you floor it from idle. ( No load, in neutral). It really is brief. It seems like it might misfire once or twice, then fine. Drives fine and the issue isn't really noticeable when driving, only when gassing it from idle. Doesn't even affect the car but the fact that it glitches like this does my head in and I need to fix it!
*Ignition system has been checked.
* MAF sensor has been replaced
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
Old 01-19-2022, 04:28 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
I always start with the factory service manual to learn how the mfr. wants the system to be diagnosed. How old is it?
Purist (01-19-2022)
Old 01-19-2022, 06:36 PM   #3
Purist
Purist's Avatar
Drives: Subaru BRZ
Early 2000s.
Less More
Old 01-19-2022, 07:08 PM   #4
Ultramaroon
not playing cards
Originally Posted by Purist View Post
Early 2000s.
I've never tried to capture data from an earlier OBD2 system. If you have something like OBDLink, or Torque, it might be helpful.
Purist (01-19-2022)
Old 01-19-2022, 07:37 PM   #5
Purist
Purist's Avatar
Drives: Subaru BRZ
Yeah. Could be an interesting learning experience.
Less More
The Following User Says Thank You to Purist For This Useful Post:
Ultramaroon (01-19-2022)
Old 01-19-2022, 09:49 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
I think the car is just reminding you it's a courier, not a race car, and nothing it does is done fast!
Hesitation on throttle when warm, negative LTFT (datalogs and vids) Grant Runion Issues | Warranty | Recalls / TSB 17 06-21-2021 10:58 PM
Max throttle opening... Uplink Software Tuning 3 02-11-2017 12:07 AM
Hesitation Under Partial Throttle! Jhood Forced Induction 27 12-06-2015 01:20 PM
EcuTek: Is there a way to limit throttle opening ? trueno86power Software Tuning 7 10-31-2015 08:34 PM
To those with the auto -any throttle lag or hesitation at low speed? ahausheer Engine, Exhaust, Transmission 22 07-25-2012 06:21 PM
