| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
Drives: '04 STi, '12 Mazda 3 Hatch
Alignment Settings & Parts
Let's talk what to change and the parts needed to change it to improve performance for street driven vehicles. Usually I'd just add a half degree of front camber and that's it but I just heard the stock spec is only 1/2° (and it can't be increased with stock parts)?!?
I figure most of you guys have the experience from the last generation to be messing with toe as well. Let's hear what new owners are finding... Last edited by Lelandjt; 01-18-2022 at 02:05 AM. |
For street driving all you should need are crash bolts in the lower hole. That usually gets you into the 1.5* range.
I’d go spc cam bolts in the lower hole and take the lower bolts and put them in the upper hole, -2 is a nice sport street camber imho.
Drives: 17 Asphalt 86
Front - Crash bolt/camber bolt. Each good for roughly 1° each.
Combo already mentioned net me -2°--2.3°(different alignment racks, same settings) Pedders offset strut mount can add an additional -0.75° or so. Rear - adjustable lower control arms/adjustable toe arms. |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Oem crash bolts go in the upper hole
| The Following 6 Users Say Thank You to finch1750 For This Useful Post: | Aroundomaha (01-20-2022), dsc_pat (01-18-2022), jvincent (01-18-2022), RToyo86 (01-18-2022), strat61caster (01-18-2022), timurrrr (01-18-2022) |
| The Following User Says Thank You to jvincent For This Useful Post: | finch1750 (01-19-2022) |
Tire choice and intended usage are important factors, along with the rest of your suspension set up.
The crash bolts are so cheap and easy they're a no-brainer for even a basic street car. Plenty more you can do after that for more camber and dialing in everything. - Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | StormTrooper (01-22-2022) |
| Global settings, EQ and time alignment | Alastor | Electronics | Audio | NAV | Infotainment | 22 | 08-01-2021 11:06 AM |
| Alignment settings/Alignment Shop | v1beeee | CANADA | 27 | 04-24-2017 04:54 PM |
| Recommended Alignment Settings? | BFIFE22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 12-27-2015 04:57 PM |
| Alignment settings for Auto club speedway | ddeflyer | Tracking / Autocross / HPDE / Drifting | 12 | 07-08-2015 08:10 PM |
| Recommended Toe Alignment Settings | brillo | Tracking / Autocross / HPDE / Drifting | 18 | 02-05-2014 11:36 AM |
