Old 01-13-2022, 02:56 AM   #1
Hags86
Drives: Toyota GTS 86
Recommend me a race turbo setup
Hi There
I've running a water-to-air turbo kit for a while and just can't get the temps low enough for my liking. Time to move to air-to-air. I've been out of the 86 scene for a few years and lost track of which manufacturer is doing what and if there has been any stand-out winners emerge over the last few years.
I'm looking for 350kW (470hp) the wheels and aim is to keep inlet air temp to 20C over ambient.
All the supporting mods are there (CP Carillo internals at 12.5:1, Motec ECU, sequential gearbox, brakes, e85 Flex fuel, crash bar etc).
I'm after the best engineered, highest quality option kit that just works.
2013 Toyota 86: 275rwkW
Coyoda Water-to-air Intercooled Turbo with GTX2863. CP Carillo Rods and Pistons. Motec M150 ECU. Motec C125 Dash. Holinger SG 6 Speed Sequential Gearbox. OS Giken LSD. MCA Reds Coilover. AP Racing Essex Sprint Front Brakes. PWR Radiator and Intercooler heat exchanger.
Hags86 is offline   Reply With Quote
Old 01-13-2022, 02:58 AM   #2
tomm.brz
Drives: brz 2017 hksv2
How do you expect a air-to-air intercooler to perform better than a air-to-water one?
The Following User Says Thank You to tomm.brz For This Useful Post:
alphasaur (01-13-2022)
Old 01-13-2022, 11:11 AM   #3
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Bigger more efficient turbo.
Water/meth injection.
Both
Old 01-13-2022, 04:38 PM   #4
Hags86
See attached. This shows that the intercooler water temp grows over time and drags the air temp with it.
There is a 10-20C degree delta between each set of temperatures in a heat exchange process as they are not 100% efficient. Intercooler water stays say 15-20C above ambient, intake air another 15-20 above that again.
Both
A bigger, more efficient turbo is part of my question.
I'm not doing water/meth injection
Old 01-13-2022, 05:49 PM   #5
tomm.brz
and removing your air-to-water system to put an air-to-air one should cool the intake charge temp down better ?
Old 01-15-2022, 09:49 AM   #6
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Welcome back.
For track use and low temps it is still hard to beat P-Tuning Competition kit. The only downside is slightly more chargepiping costing a fraction of transient response. If I were ever go back to another turbo setup on this playform I'd easily pay the premium price to get away from the front mounted setups.
Old 01-15-2022, 10:21 AM   #7
Pat
Pat's Avatar
Drives: 2023 BRZ
Do what @CSGMike did.
Old 01-15-2022, 07:50 PM   #8
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by Kiske View Post
Welcome back.
I've always wanted to see the PTuning kit with an air to water intercooler mounted on top of the engine. It should make the transient response on par with any other kit and you get the excellent hot side setup. Though clearly that wouldn't help OP.
Old 01-16-2022, 01:31 PM   #9
Pat
Pat's Avatar
Drives: 2023 BRZ
What kind of racing do you plan on doing? (i.e. drag, autocross, sprint, endurance, airstrip, etc.)
Old 01-17-2022, 10:27 PM   #10
Water can absorb more heat in bursts. You just have to also be able to shed that heat, and packaging becomes a challenge.
Real world example: Ferrari vs Mclaren.
Old 01-23-2022, 02:51 PM   #11
Icecreamtruk
Drives: Track preped NA FRS
Shouldnt air to air work better than water to air? Unless im missing something, in a water to air sytem you still need to cool down that water, that in turn is used to cool down the air. Two steps = less efficiency in the overall heat exchange (loss at each step).
Sorry OP, I have no idea regarding turbo setups. I swapped to an LS because I didnt think any turbo setup would beat the reliability and power delivery of a big NA engine.
Old 01-25-2022, 10:27 PM   #12
Sort of.
The water can absorb more heat faster out of air (charge to intercooler), then air can; the delta is larger. But then, the water has to shed that heat back into the air (intercooler to ambient), which is more difficult to do, since the delta is now smaller.
Double edged sword.
I don't think OP's goal of 20C over ambient is very realistic at that power level, unless OP has huge money to burn on the cooling setup. It will require far more than just a bolt-on kit.
Icecreamtruk (01-25-2022)
Old 01-26-2022, 01:20 AM   #13
jflogerzi
jflogerzi's Avatar
at that WHP he is going to have more than just cooling issues to worry about. 470 is a pretty lofty goal and under race conditions(still don't know what type) you better have a pretty large check book.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
CSG Mike (01-26-2022)
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring Engine, Exhaust, Bolt-Ons 8 10-30-2015 07:36 AM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring NY / NJ / CT / PA 0 10-20-2014 11:48 AM
N/A power output potential as race setup? rice_classic Engine, Exhaust, Transmission 67 12-17-2013 08:03 PM
Orido's Race Sim Setup juliog Off-Topic Lounge [WARNING: NO POLITICS] 4 12-04-2013 02:09 PM
