Old 01-06-2022, 02:21 PM   #1
ThaDonJsuan
Drives: 2020 Subaru BRZ Sport-tech
Please help - thumping sounding issue with accelerating with turned wheels
Hi all,
I am having an issue with my 2020 BRZ that i just started noticing recently now that its cold (not sure if its related to the cold).
When I reverse out of my driveway ill turn the wheel so that my back end rotates. Then ill start to go forward and ill turn the wheel to the other side to start driving in the lane but when i accelerate slowly there is a thumping sound at the front of the car which causes the front to slightly shake. It doesn't matter which way i turn. Once the car is straight or close to straight the thumping stops. The only mods i have are camber bolts up front with -1.7 degrees and stainless steel brake lines. Any ideas? Thanks very much in advance.
ThaDonJsuan is offline   Reply With Quote
Old 01-06-2022, 02:24 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
a video would help. also get out and check the clearance around the front tires with them turned slightly-- could be part of the fender liner
on my truck, that's exactly the scenario that my front tire will catch the edge of my mud flaps, and make that noise.
but i suspect you have neither mud tires, or big floppy mud flaps.
Old 01-06-2022, 02:33 PM   #3
ThaDonJsuan
Thanks! I will get a video but interestingly, once i drive for a few minutes i cant replicate the issue. It will only happen again once the car sits for a while and 'cools down'. Ill need to wait a bit before going back out and getting a vid.
Old 01-06-2022, 03:12 PM   #4
nripinbabu@gmail.com
Drives: brz
wider tires do that when weather is cold out, its normal , will go away once weather warms up
nripinbabu@gmail.com is offline   Reply With Quote
Old 01-07-2022, 12:59 PM   #5
ThaDonJsuan
Thanks! This actually does make a lot of sense now
Old 01-11-2022, 06:26 PM   #6
Do you have wider tires? Do you have snow tires?
Not exactly sure what physics would be involved in larger tires causing this just because they are cold.
soundman98 (01-11-2022)
Old 01-11-2022, 09:42 PM   #7
Ultramaroon
not playing cards
Ultramaroon's Avatar
Is it icy where you take off from your driveway?
Old 01-12-2022, 01:01 AM   #8
soundman98
soundman98's Avatar
well clearly, tires swell when they absorb the water from driving in the winter. which causes them to rub.
physics has no place in reality, apparently.
Old 01-13-2022, 01:05 PM   #9
Carsnguitars
Drives: 2014 FR-S
Maybe low tire pressure and/or flat spotting? Once you get moving they even out...?
Carsnguitars is offline   Reply With Quote
The Following User Says Thank You to Carsnguitars For This Useful Post:
Wally86 (01-13-2022)
Old 01-13-2022, 02:36 PM   #10
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Another thing I could think of would be potential ice/snow build up in your wheels causing them to be (temporarily) unbalanced?
But then that should give you thumping even while going straight...
daiheadjai is offline   Reply With Quote
Surging/stalling when accelerating. intermittent issue scarysquash Issues | Warranty | Recalls / TSB 17 09-09-2025 12:16 PM
Thumping Sound After J02 Recall razman Issues | Warranty | Recalls / TSB 7 03-15-2019 10:56 AM
Low RPM/Speed Thumping Noise? gatorbushmen Issues | Warranty | Recalls / TSB 2 05-18-2016 05:37 PM
thumping / clunking in trunk? HotLavaChick Issues | Warranty | Recalls / TSB 11 10-13-2015 10:02 AM
Having fun turned into an issue DrDuquette Issues | Warranty | Recalls / TSB 8 01-14-2014 10:44 AM
