Old 01-11-2014, 12:20 PM   #1
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
Having fun turned into an issue
So I was just out having fun in an open lot and spun out. I spun the car about 3/4 around and stopped. I'm not sure if it was me or the car that caused it to stall. After that I was trying it start it up again. It wouldn't start us. The motor would just turn over and over but not start. I turned the key all the way on an off again a few times. About 20 seconds later was able to start it again. Is there some kind if safety computer that makes this happen? I'm just wondering why it didn't start right up? Thanks for you help ahead of time.
DrDuquette is offline   Reply With Quote
Old 01-11-2014, 12:22 PM   #2
Muskokan
Drives: white Sport-tech
theres been a couple threads on cold starts doing this,
havent heard anything much about warm starts, but im gunna assume seeing as you didnt know if it was you or the car that it was possible you had your foot on the gas after it died and you flooded her a bit.
possible? just chucken ideas
Muskokan is offline   Reply With Quote
Old 01-11-2014, 12:56 PM   #3
mad_sb
Drives: 2013 Asphalt FR-S
Fairly sure i have seen other threads describe exactly this.. It's possible the ecu goes into a fuel system shutdown if it "detects" an accident or roll over or something of the sort. You probably just upset the over-lord nanny with your spin. I have had it act similar once at a drift day on a big off i had. I had to key off completely then it started up. Did not take 20 seconds though.
Old 01-11-2014, 01:51 PM   #4
strat61caster
strat61caster's Avatar
But it started after a minute or two right? You didn't need to be towed.
You were goofing around so I assume the engine is warmed up eliminating the cold start possibility. I'd guess you either flooded it or upset the ECU somehow, give it a minute to rest and it should be good to go, cars do weird things when put in abnormal situations, as long as you didn't hear parts breaking I wouldn't worry.
ineedyourdiddly
Mr.EvoMR (01-11-2014)
Old 01-11-2014, 03:02 PM   #5
DrDuquette
DrDuquette's Avatar
Thanks guys. Nothing really weird. Back end slid around and then just stopped quickly. Didn't hit anything. Warmed up yes. Been driving 5 mins already. Im thinking you might be right about flooded. I'm sure this happens at auto crossing and drifting events occasionally. Right it did start up fine eventually.
Old 01-11-2014, 04:30 PM   #6
zooki
Drives: waiting on a 2021...
Mine has done the same thing. It will even turn the CEL light on, but when I run the code scanner in my Torque app nothing comes up. If I turn the car off and start it back up the CEL is off.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
The Following User Says Thank You to zooki For This Useful Post:
DrDuquette (01-11-2014)
Old 01-14-2014, 09:15 AM   #7
Mike86
Drives: Scion frs
Same thing happened to me a few times after spinning out and stalling i just leave my key in the on position for a few seconds and it starts after prbly just some flooding i wouldnt be too worried
Mike86 is offline   Reply With Quote
The Following User Says Thank You to Mike86 For This Useful Post:
DrDuquette (01-14-2014)
Old 01-14-2014, 09:21 AM   #8
DrDuquette
DrDuquette's Avatar
I love this forum. Even though sometimes it seems to get out of hand, it is always so helpful when it comes to solving issues or pushing the envelope! Thanks
Old 01-14-2014, 09:44 AM   #9
DR 86
DR 86's Avatar
It's not flooding, it's a fail safe to cut the fuel system. Happened many times on track. Just turn it all the way off and restart, it'll fire right up.
Perrin CAI|Perrin MCB|P&L header|Motiv OP/FP|MXP catback|Tein Type Flex coilovers|Eibach F/R sway bars|GS front strut brace|Street:PM HC+800/Track:Carbotech XP10|StopTech slotted rotors/SS lines|SBC RPF1s|Street:FK453/Winter:Pirelli SottoZero3/Track:Toyo R888s|Leg Sport rear spoiler|EcuTek Tuned|OEM oil cooler|4th/F1 brake lights
DR 86 is offline   Reply With Quote
The Following 3 Users Say Thank You to DR 86 For This Useful Post:
DrDuquette (01-14-2014), strat61caster (01-14-2014), zooki (01-14-2014)
Coffee, my love, why have you turned on me??? sho220 Off-Topic Lounge [WARNING: NO POLITICS] 77 09-25-2020 06:38 PM
Photoshoot Turned Into This.... Vicious LED FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 48 04-01-2013 08:03 AM
Turned down BRZ today. Le sad Nat BRZ First-Gen (2012+) — General Topics 29 09-30-2012 12:51 PM
Turned 21 today Exhaust Off-Topic Lounge [WARNING: NO POLITICS] 23 07-22-2012 07:23 PM
ABS button....means ABS be turned off? Shadowsong6 Scion FR-S / Toyota 86 GT86 General Forum 35 12-06-2009 01:20 AM
