New ECU regulations in CA?
I have a 2013 FR-S with a tuned ECU (I'll explain). My smog is coming due and I'm concerned that I will fail smog because the ECU is supposedly tuned to remove the well-documented torque. I say supposedly because it came with an ECU flasher and I was told the work had been done. Can I reflash it back to the original? Will the smog tester know or am I ok reflashing it back to the original specs?
#2 | |
Sent from my SM-G975U using Tapatalk |
#3 | |
Dismember
Drives: 2013 Red Scion FR-S
Wheels for Brains
I just smogged recently and passed just fine after flashing back from an Ecutek tune to the stock base tune
Dismember
Then it is pretty easy to use that OpenFlash tablet to restore to stock. After smog, reflash the tune if you want.
I went back to stock recently. I used Tactrix, which is a bit more difficult but not hard.
| The Following User Says Thank You to EAGLE5 For This Useful Post: | strat61caster (12-27-2021) |
Drives: 2015 Scion FR-S
I'm so glad i'm leaving CA soon. It's so silly to have to deal with this stuff
| The Following 4 Users Say Thank You to e_lunatic For This Useful Post: |
The reflash was insanely easy. Now, after reading my ECU I see there's a PO420 code. I have 3 options...
1) New catalytic converter. Yeah, no. 2) O2 bung. I wonder if the smog technician will open the hood and inspect it. I haven't had a chance to really see where it is or if it would be obvious. Does have a picture of where exactly it's located? 3) Citric acid wash. I've done this before and it works incredibly well. Cat soup anyone? |
#9 | |
Wheels for Brains
You won't pass a real smog visual with an aftermarket header. I recommend either buying a used one or borrowing one and swapping it. The header itself on the FA20 engine has a catalytic converter, along with the front pipe. The only exhaust emissions sensor is located on the header; it's near the header-to-overpipe connection. In the area pictured below, you'll find a pair of twin connectors (one black and one gray); these are for the Heated O2 and AFR sensors on the header, respectively. P0420 deals with the black O2 sensor; follow the black sensor connector and wire down on the left side of the engine |
#10 |
Road-hole
Drives: 2013 Whiteout FR-S
I left 3 years ago..
| The Following User Says Thank You to Jaden For This Useful Post: | e_lunatic (12-30-2021) |
#11 | |
#12 |
Wheels for Brains
| The Following User Says Thank You to EndlessAzure For This Useful Post: | soundman98 (12-31-2021) |
#13 | |
2013 Series 10 FRS #553
#14 |
| EU Alert: Toyota GR86 on sale for just two years due to new regulations | Blighty | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 8 | 12-04-2021 12:31 PM |
| Japanese Super GT’s New Regulations Previewed on Toyota GT 86 | vh_supra26 | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 09-16-2014 01:37 PM |
| New F1 regulations: significant redesign of vehicles | 1Cor10:23 | Off-Topic Lounge [WARNING: NO POLITICS] | 22 | 12-07-2013 08:51 AM |
| 2012 ARC Regulations | coyote | AUSTRALIA | 4 | 12-05-2011 01:48 AM |
