Old 12-15-2021, 05:04 PM   #1
lapsio
lapsio's Avatar
Drives: 2020 BRZ Final Edition, 1999 MX5 NB
Newbie question: When does clutch burn?
Sorry for potentially dumb question but what are conditions that cause clutch to burn? I'm kicking clutch quite often to put my BRZ off balance in order to slide on turns or whip an U turn. Sometimes on rare occasions I can smell the clutch. It's quite rare, so far maybe I smelled it like 3-4 times (out of 100 kicks or so).
I used to think that it happens when there are good conditions and tires are just too grippy so clutch can't stand that but recently I smelled clutch when launching on snow and I was like... wait... hold up. What the actual f*ck. It was like -4 outside 1 inch layer of snow, car was super cold, literally 0 traction whatsoever I launched it, did "burnout" at like 2kph because it was too slippery to even gain some speed and smelled clutch?... It seemed off... So when really does the clutch slip causing burn? Did I have too high rpm or something? Could it be that transmission was too cold and something funny happened? When clutch kick in BRZ can lead to burnt clutch? When kicking clutch am I supposed to rapidly let off clutch completely rapidly or give some super brief slip like 0.2s in order to not put too much stress on transmission? Car is fully stock. I'm on winter tires so I don't think they're all that much grippy...
inb4 it's my first rwd car and I only made 6k km so far so I don't have much experience driving such cars so there's extremely high chance I'm doing something terribly wrong.
lapsio is offline   Reply With Quote
The Following User Says Thank You to lapsio For This Useful Post:
Ultramaroon (12-21-2021)
Old 12-15-2021, 07:06 PM   #2
Grady
Grady's Avatar
Clutch dumps, burn outs, slipping clutch will wear it out quicker. Good news is the clutch on this car is easy to change. Have fun, burn out the clutch and change it. Then repeat until you are tired of doing it.
Old 12-15-2021, 07:37 PM   #3
PenGun
Drives: Red 2019 Subaru BRZ
"whip an U turn" That's what the armrest is for. I could do a 180 in an actual Mini Cooper quite happily, and under control. I have not tried my BRZ, I'm very old.
Alright silence. What I mean is the handbrake is what you use for a handbrake 180:
PenGun is offline   Reply With Quote
Old 12-21-2021, 08:37 PM   #4
Purist
Purist's Avatar
Drives: Subaru BRZ
I burned out my clutch doing short warm up burnouts and aggressive gear changes on slicks. It was magical; the air was full of shiny little fragments of clutch reflecting the sunlight.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
Old 12-21-2021, 10:58 PM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
By the smell. It smells like burned, deep fried, cauliflower to me
Old 12-21-2021, 11:07 PM   #6
Purist
Purist's Avatar
Drives: Subaru BRZ
Nailed it.
Less More
The Following User Says Thank You to Purist For This Useful Post:
soundman98 (12-21-2021)
Old 12-21-2021, 11:45 PM   #7
Ultramaroon
not playing cards
Ultramaroon's Avatar
Actually, a well-executed clutch kick adds little to no extra wear to the clutch. My explanation may sound condescending but I don't mean it that way. I'm just pointing out stuff using physics-speak.
Clutches burn when they exceed a certain temperature.
Work = energy = heat
We need to dump energy into the clutch in order to heat it.
The engine does no work at all when the clutch is disengaged.
All the work from the engine goes into the transmission when the clutch is fully engaged.
When the clutch is slipping, some of the work from the engine goes to spinning the transmission. The rest of the work goes into heating the clutch.
Work is force applied through a distance, or torque applied through an angle of rotation. We can also think of it as torque through the number of revolutions in which it is applied.
Consider slipping the clutch for a whole second at idle speed. The crankshaft will have made about twelve revolutions in that time.
Now do it for a whole second at 3000 RPM. That's about fifty revolutions; over four times as many revolutions as those at idle.
So, if you slip the clutch for a quarter second at 3000 RPM, it's about as much thermal energy as slipping it at idle for a full second.
To control temperature, limit the time AND torque applied while slipping. If you ever feel it get spongy while slipping it, that's the feel of hot clutch. Avoid that and you're golden
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
RToyo86 (12-22-2021), soundman98 (12-22-2021), Tcoat (12-22-2021), villainous_frx (12-22-2021)
Old 12-22-2021, 12:42 AM   #8
soundman98
soundman98's Avatar
And long before that point does the smell of hot clutch waft into the cabin
Ultramaroon (12-22-2021)
Old 12-22-2021, 01:09 AM   #9
Ultramaroon
not playing cards
Mmmmmmmm.... not necessarily. Maybe I'm just extra sensitive but I've always felt it before smelling it. Worst was when I was teaching a friend how to drive stick. He got pretty good at level stuff so we tried a hill start. I knew it was bad just listening from the passenger side so I stopped him. Smelled it when we swapped places. Oh, man, it was like stepping on a loaf of Wonder bread. So many feels.
Old 12-22-2021, 11:14 AM   #10
Mars
Mars's Avatar
Drives: 2014 Scion FR-S
This makes sense to me (an accountant who wishes he spent more time studying physics). My only question is, if you're "dumping" the clutch rather than giving it a very quick slip, is the "shock" doing more damage to the clutch than the heat at that point? I would think it saves heat since there's less time slipping but wouldn't that instant jump in torque "shock" something in the system to cause extra wear than a light slip? Just genuinely interested in knowing since I too like to kick it out on the occasional U-turn (FRS drivers, am I right lol).
Mars is offline   Reply With Quote
Old 12-22-2021, 12:52 PM   #11
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
You can drive purdy much any way you want, as long as you acknowledge the consequences. It's a sliding scale: More abuse, the faster things wear out and break. The more you baby her the longer she'll last and be less likely to leave you stranded.
The Following User Says Thank You to blsfrs For This Useful Post:
Old 12-22-2021, 02:27 PM   #12
Ultramaroon
not playing cards
Yes. Absolutely right, but it's not a dump. It's a well executed clutch kick. Potato-potahto?
Bottom line is the shock felt by applying high torque for a short time does not burn clutches. It might break something downstream, but it won't be the clutch.
Just don't get caught
Old 12-22-2021, 03:06 PM   #13
Mars
Mars's Avatar
...Bottom line is the shock felt by applying high torque for a short time does not burn clutches. It might break something downstream, but it won't be the clutch.
Well I will continue my current method as I've been doing it for a while and haven't seemed to have had any clutch issues nor smells! Also helps that I got a stage 2 since I knew I wanted to kick it a lot.
Old 12-22-2021, 09:45 PM   #14
soundman98
soundman98's Avatar
it's the "is it better to brake long and slow, or short and fast?" question.
i think the true answer lies somewhere in between.
Newbie Question Offyman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 08-01-2020 10:34 AM
OFT newbie with a question ksconekiller Software Tuning 16 07-18-2015 09:34 PM
newbie OFT question 2much Software Tuning 5 11-13-2014 08:59 PM
Newbie Question! ButtonMasher Tracking / Autocross / HPDE / Drifting 5 04-10-2014 04:20 PM
question about frs for a newbie enjoi23 Scion FR-S / Toyota 86 GT86 General Forum 18 08-04-2012 05:42 PM
