Old 11-19-2021, 11:04 AM   #1
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Pedders top hats
I know about the camber/caster adjustment these offer, but are there any negatives for the stock struts running these? Will it impact the operation/life of the struts at all or am I just overthinking this?
dragoontwo is offline   Reply With Quote
Old 11-19-2021, 11:30 AM   #2
Tatsu333
Drives: 2020 BRZ Sport Tech RS
There shouldn't be any negative impacts on the struts with these, as the actual magnitude of the camber and caster changes are quite minor.
They just give that *little* bit extra that will help get things within a more performance-oriented range alignment-wise without going to a full camber/caster plate and the potential NVH those bring.
Tatsu333 is offline   Reply With Quote
Old 11-19-2021, 01:20 PM   #3
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
I’ve run the Pedders top mounts for two years now with no issues.
For the record my current set-up is TRD springs on Koni Yellows with camber bolts at both locations (16mm top, 14mm bottom).
With these parts a -2.75 front camber is easily achieved. In fact my alignment guru stated he could get -3.5 but that would be too extreme for my 95% DD of that time. This works okay for lapping although now that I’m retired I would opt for the -3.5 had I not recently bought a set of Ohlin’s which included adjustable camber plates. I’ll install these this winter using the camber bolts for some -5 degree spring track fun.
Muskoka800 is offline   Reply With Quote
The Following User Says Thank You to Muskoka800 For This Useful Post:
RToyo86 (11-25-2021)
Pedders Top Hats - Add camber without sacrificing wheel clearance Anthonyc777 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 49 04-07-2026 12:17 AM
Pedders Ezfit fujin86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 08-05-2021 05:15 PM
Pedders top hats and subaru camber bolts... results. 7 skulls Suspension | Chassis | Brakes -- Sponsored by 949 Racing 58 02-01-2021 06:24 PM
FS: Robispec rear top hats, OEM front top hats, Scion wheel caps, OEM coin holder MyRx Brakes, Suspension, Chassis 5 10-12-2014 02:14 PM
New Pedders Coilovers for the BRZ and FR-S! RallySport Direct Brakes, Suspension, Chassis 4 06-11-2013 05:42 PM
