Old 11-04-2019, 12:17 PM   #1
fujin86
Drives: Steel 2015 Frs automatic
Pedders Ezfit
Anyone ever run this or know much about it, I have scoured the internet and found like 1 review, they seem better than going for cheap coilovers for the 1in drop I want.
fujin86 is offline   Reply With Quote
Old 11-04-2019, 12:19 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
What are you really looking for in a coilover if you only want a 1" drop? You know that the Eibach pro kit and several other spring companies give you the same drop on OE suspension right?
Old 11-04-2019, 12:22 PM   #3
wparsons
wparsons's Avatar
These are what he's after, completely assembled already.
https://pedders.com/collections/suba...z-2012-present
OP, I wouldn't suggest getting those at all. Shocks will be worse than stock, upper mounts will be cheap, who knows what the spring rates are, etc.
flickr
Old 11-04-2019, 12:25 PM   #4
DarkPira7e
DarkPira7e's Avatar
Oof, for that cost he could have some ST coilovers!
Old 11-04-2019, 12:34 PM   #5
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Why go this route when there are quality pieces available for lower or like cost?
Old 11-05-2019, 10:09 AM   #6
wparsons
wparsons's Avatar
Those don't include upper mounts, but you're not far off. New mounts would push it over $1000 for OEM or Group N mounts.
flickr
Old 11-05-2019, 10:45 AM   #7
What am I missing? They look like coilovers already to me.
Old 11-05-2019, 11:02 AM   #8
Racecomp Engineering
Technically correct!
Shameless plug (slide 5 onwards):
https://www.instagram.com/p/B4DFiFBg...d=7jfd2qhtfarn
- Andrew
Old 08-05-2021, 05:15 PM   #9
BostonJack
Drives: 2013 Scion FRS manual transmission
install of Pedders FRS coils and struts
I just had all four struts replaced with the Pedders ezfit kit on my fairly high mileage (94k) FRS.
full disclosure: this is a daily driver, I've never raced on a track, so take that for what it is worth
Immediate and dramatic improvement in handling. Stiff, but incredibly well damped. I don't plan to take advantage of the camber range of adjustment.
My mechanic was impressed and told me to expect improved chassis feel and, gosh, he was right.
Jack
BostonJack is offline   Reply With Quote
Pedders top hats and subaru camber bolts... results. 7 skulls Suspension | Chassis | Brakes -- Sponsored by 949 Racing 58 02-01-2021 06:24 PM
Pedders offset front strut mount? Any knowledge? 7 skulls Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 03-20-2019 03:20 PM
Pedders Top Hat w/ Camber & Caster Offset - Anyone with experience? Jamestl Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 11-16-2018 04:35 PM
Pedders Suspension Now Available At RallySport Direct RallySport Direct Brakes, Suspension, Chassis 9 10-17-2016 06:37 PM
New Pedders Coilovers for the BRZ and FR-S! RallySport Direct Brakes, Suspension, Chassis 4 06-11-2013 05:42 PM
