Old 11-18-2021, 10:03 AM   #1
Th3rdSun
Drives: 2013 FR-S MT Hot Lava
Weird lighting/electrical issue.
So I have an issue where my driver's side turn signal isn't on,but it will flash when I engage it to turn left,so I know it's not the bulb,which I did replace fairly recent.Both side markers are completely out and won't illuminate at all.Also,the taillights work perfectly fine,which while I was searching for a solution,this was brought up.
I also have a problem with both 12v ports(center armrest area and in the glove box).I checked the fuse under the dash and replaced it,twice. When I plug in a charger,it works for a second or two,then blows.Tried different chargers with the same results.I have no idea if this is related to the lighting issue,but there are definitely some gremlins at work here.Anyone have any ideas?
Th3rdSun is offline   Reply With Quote
Old 11-18-2021, 10:14 AM   #2
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
When you replaced the bulb, did you replace it with an LED bulb? Did you replace the flasher relay as well?
Clueless
YamahaR86 is offline   Reply With Quote
The Following User Says Thank You to YamahaR86 For This Useful Post:
Th3rdSun (11-18-2021)
Old 11-18-2021, 10:43 AM   #3
Th3rdSun
I replaced it with the exact same type of bulb that I removed. Not LED. I didn't not replace the relay.
Mind you,I replaced the bulb around April or May,and it worked perfectly fine. I only recently noticed that the bulb is acting funny now. I'm not getting the fast turn signal inside of the car with the blinker is completely out,and it actually flashes when it's engaged.
I'll check the relay though.
Old 11-18-2021, 02:50 PM   #4
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
Your side markers and turn signal kind of point me towards a headlight wiring, since they aren't "on" as a running light until you switch your headlights to the on position.
Might be a short somewhere like an exposed wire that is hitting something.
Clueless
Old 11-18-2021, 03:29 PM   #5
Th3rdSun
Just to be clear,whether the headlights are on or off,the left blinker works,but it doesn't stay on like the light on the other side. The side markers are just off completely,lights on or off,and won't work when the blinker is engaged.
If I get time tonight,I'll check that blinker relay to see if that could be the problem,if it isn't,then I just don't know,other than a short somewhere,which more than likely will be a pain in the ass for me to find.
Old 03-07-2022, 11:27 PM   #6
Th3rdSun
Ok,so I'm an idiot. I know it's been a while,but I finally got a chance to figure out what was wrong with my light. It was because I replaced the burnt out bulb with a single filament bulb instead of a dual filament bulb.
The Following User Says Thank You to Th3rdSun For This Useful Post:
soundman98 (03-08-2022)
Complex BRZ Electrical/ECU Issue -- Need help! mackemode Issues | Warranty | Recalls / TSB 14 07-09-2020 11:45 AM
Electrical Issue TeamJacobs111711 Issues | Warranty | Recalls / TSB 15 08-06-2018 01:41 PM
Weird Electrical Issue Relogical Issues | Warranty | Recalls / TSB 0 04-19-2018 02:09 PM
Weird electrical problem itsAlex Scion FR-S / Toyota 86 GT86 General Forum 24 08-17-2016 07:56 PM
Weird electrical issues. Need help! Pneub Issues | Warranty | Recalls / TSB 15 09-13-2014 12:38 AM
