Old 11-10-2021, 08:02 PM   #1
Enrique_13
Drives: 2013 Subaru BRZ
Code P0420 Catalyst System Efficiency Below Threshold (Bank 1)
Hey guys, I need to replace a faulty catalytic converter, I guess the JDL UEL header didn’t work out in the long run. Is there any advice on replacing this? I’m not sure if I have to spend a whole $1300 on a part or looking for a simple basic one that could be cheaper. Thank you
Enrique_13 is offline   Reply With Quote
Old 11-10-2021, 08:51 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You need to elaborate more on what mods you have. So you have a JDL catted UEL header, you do know those are not guaranteed to not give you a P0420 right? Doesn't mean the cat has failed. You can either try using one of those cheesy O2 spacers or get the the car tuned proper and have P0420 disabled.
Verify the problem, then repair. A code is a result of a symptom, but you haven't diagnosed the actual cause.
Old 11-21-2021, 05:09 AM   #3
jflogerzi
jflogerzi's Avatar
Simple fix. Get an OFT and run a tune to take advantage of the header plus it will disable the code. As others have said just because you have a cat, if it's not stock no guarantee you will not get a code. How long have you had the header? I know JDL had some quality issues with there old cat supplier and that's why they stop selling them for a while.
Sent from my Pixel 5a using Tapatalk
2013 Series 10 FRS #553
P0420 CODE SHOGUN66 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 10-24-2018 09:42 AM
P0420 Code Miguelgomez Southeast 0 01-25-2018 09:41 PM
CEL P0420 Code. VoltsFRS2013 Engine, Exhaust, Transmission 22 10-10-2017 12:26 PM
P0420 Code... Need help R3b00T Engine, Exhaust, Transmission 4 07-11-2016 04:18 PM
Code p0420 Patsully3 Issues | Warranty | Recalls / TSB 17 02-26-2016 10:45 PM
