Old 08-13-2018, 10:47 PM   #1
SHOGUN66
SHOGUN66's Avatar
Drives: Scion FR-S
Exclamation P0420 CODE
Hello all,
Just a little background on my car
2013 Scion FR-S Automatic, 82000 miles, Stock Everything
I just have a quick question for everyone. My car is throwing a P0420 code,
Catalyst System Efficiency Below Threshold (Bank 1).
Now the only reason I'm bringing this on here is if someone could tell me where to start. I have tried that stuff you put in your gas and that made it go away for awhile, but it just came back. I guess the band aid ripped off!!
So all In all I want to march down to Toyota and get them to replace the converter. But I KNOW they are going to run me about 1200 bucks (previous quote). So I don't want to do that and then find out the problem was the 02 sensors or something minute.
So if someone could shed some light or at least point me in the right direction, that would be awesome!
Best Regards,
SHOGUN66
SHOGUN66 is offline   Reply With Quote
Old 08-13-2018, 11:01 PM   #2
steve99
Yes P0420 indicates the ecu "thinks" the cat converter in header is performing below specification.
But it can get fooled by exhaust air leaks ,bad or failing 02 sensors , cracked header
You rearly need to look at logs and evaluate before throwing parts at it
Assume your car is stock with stock header and intake and your running correct fuel
In performance\tuning worlds just pit on a aftermaket catless header and tune would cost less than replacement cat header from Toyota
Old 08-14-2018, 05:40 AM   #3
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Also a wiring issue can cause this too.
You can find OEM headers and FP's on Ebay for cheap. People delete cats and sell them all the time. Hell I have them on Craigslist myself. But only the header cat is tested for P0420, don't worry about the FP. Florida has no emissions testing so this is probably the best place to look for them.
Get it diagnosed professionally (yeah it'll cost a few bucks but it'll save you a lot of money in the long run- because if you start throwing parts at the problem not knowing what it is, you'll run our of money before you runs out of guesses!) then you can buy the parts yourself.
If you do need a header, PM me, I have one for sale. It's $150 + shipping not $1200!
Old 08-14-2018, 08:52 AM   #4
SHOGUN66
SHOGUN66's Avatar
Drives: Scion FR-S
Is there some other place other than Toyota that I can get a accurate read on what's wrong, and they wont bullshit me? I guess I will just have to ask around here.
Thanks again man
-SHOGUN66
Old 08-14-2018, 01:36 PM   #5
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
Thanks again man
-SHOGUN66
The only time I've ever had p0420 was when I had a catless header untuned. Your cat may just be done as you suspected. People have blown out aftermarket catted front pipes easily with less miles before. If you had an exhaust leak bad enough to throw a code you'd likely hear it and the code would probably be p0171 or another fuel trim related code due to the fresh air entering your exhaust system.
MCTeeJ is offline   Reply With Quote
Old 08-14-2018, 08:28 PM   #6
guybo
Huge E85 fan!
guybo's Avatar
Thanks again man
-SHOGUN66
Call some local shops, ask if they can do diagnosis. Bolting on parts is easy, diagnosis is hard
Old 08-14-2018, 11:08 PM   #7
SHOGUN66
SHOGUN66's Avatar
Drives: Scion FR-S
Hey so if I were going to get the Invidia Headers (SKU: INV-HS12SS1HDP) , would I need to buy any other parts?
Or would I need the front pipe, over pipe, etc?
Thanks
Old 08-15-2018, 01:29 PM   #8
Vital
Drives: 2015 BRZ
Thanks
No you dont need to buy any other additional parts. You can just simply swap out your OEM header for the Invidia one. Also, if you do get aftermarket headers you will need to get a tune for it or else you will get other codes as well.
Vital is offline   Reply With Quote
Old 10-23-2018, 10:38 AM   #9
Activ8
Drives: 2013 Whiteout Scion FR-S
I see a lot of posts about swapping the header. My question is, how does the P0420 code even show up on relatively new cars?
I have a 55k mile FR-S and the code just popped up. It's most surely the O2 sensor because temps dropped around 20F pretty quick from one day to the next in Michigan Oct 2nd week. That probably causes the fuel to run richer. But seriously, should this happen in a barely run (for a Toyota) car? OP is in Arizona so I'd atleast think he shouldn't be seeing this problem?
Guybo - you mentioned it could be a wiring issue - can you elaborate? Would you need a header cat replacement in such a case? Michigan too has no emissions testing, so I can find parts locally with a ton of folks parting out all the time on the MI86 club.
As per posts above, I'm not going to my local Toyota dealer because they want $125 just for diagnozing the problem - I already know what the issue is. Plus parts and labor - the whole thing could run up a bill of $1200 bucks and I'm not trying to get fleeced. But the question remains as to why this should pop in a car so new and driven smoothly without any aftermarket mods.
Activ8 is offline   Reply With Quote
Old 10-23-2018, 12:44 PM   #10
MCTeeJ
MCTeeJ's Avatar
I would look further into it before condemning the o2 sensor. Granted, it's not that likely for a cat to go this early either, but stranger things have happened. When an o2 sensor "goes" it'll usually peg in either direction and max out the fuel trims, thus throwing a fuel trim code like max rich or max lean condition, not a cat efficiency code.
Old 10-24-2018, 09:42 AM   #11
Activ8
Fair point. I was going mostly by my experience as an automotive engineer. Also, under federal law, the catalytic converter and engine-control module are covered for eight years or 80,000 miles. (*Under California law, 15 years). So technically I wouldn't pay anything for a replacement. But my Toyota dealer says this isn't under warranty which leads me to believe they will 'diagnoze', and then only change the O2 sensor/MAF sensor. Big bill.
Also, similar to my thought process is the P0420 OBD II Code help:
P0420 OBD-II Trouble Code Guide: Catalyst System Efficiency Below Threshold (Bank 1)
When your check engine light comes on with a P0420 code, that can mean only one thing – an expensive trip to your auto mechanic.
But don’t worry, we’ve outlined a few steps in this article you can take to avoid taking your car in for repairs.
The P0420 error code is a sign that your catalytic converter is under performing. That could mean it needs to be replaced or just possibly cleaned.
The good news is that we’ve uncovered the easiest ways to fix those catalytic converter problems so you can get back out on the road without spending a fortune.
Quick ways to fix a P0420 code:
1.Check the exhaust system for potential leaks
2.Use Catalytic Converter Cleaner to remove any build-up in the system
3.Fix or replace damaged oxygen sensors (special tool required)
4. Replace the catalytic converter
What does the P0420 OBDII error code mean?
Whether you want to call them OBDII (on-board diagnostic) codes, diagnostic trouble codes, error codes or check engine codes – they all imply the same thing: you’ve got car trouble.
In your case, the P0420 code stands for “Catalyst System Efficiency Below Threshold (Bank 1).”
When you receive a P0420 code it means your catalytic converter is not operating at maximum efficiency. Usually this means your catalytic converter needs to be replaced or there is a problem with your O2 (oxygen) sensors.
You may not notice if you have catalytic converter problems but the environment will. A catalytic converter helps reduce your car’s emissions. It does this by converting the carbon monoxide in your exhaust into carbon dioxide and water.
If you continue driving without fixing this problem you may not pass your vehicle emissions test or smog check.
As I mentioned above, the P0420 code means that your catalyst system efficiency is lower than it should be, as measured by your O2 (oxygen) sensors. This means there may be a problem with either the catalytic converter, the oxygen sensors, or both.
The 02 (oxygen) sensor is designed to monitor the fuel and air mixture in the exhaust to verify that the engine is running efficiently. Your engine control unit (ECU) will use this information to adjust the engine performance as you’re driving. When your O2 sensors are working properly you will get better gas mileage and optimal performance.
After your check engine light comes on and you verify the P0420 error code, there are a few simple steps you can take. First, you should check the entire exhaust system for any visible holes or deterioration.
If the exhaust looks intact you may need to replace the catalytic converter. While it may not be necessary, you could also replace your O2 sensors while you’re under there. That way you don’t have to do it later down the road, if they are in fact damaged.
Source
This is similar to other information available online.
Anyways, I've given it to my local mech tech and expect to see the estimate/diagnosis of the car back today.
Bogging when clearing P0420 code? Moooiiissst Engine, Exhaust, Transmission 16 08-07-2018 08:15 AM
P0420 Code Miguelgomez Southeast 0 01-25-2018 09:41 PM
CEL P0420 Code. VoltsFRS2013 Engine, Exhaust, Transmission 22 10-10-2017 12:26 PM
P0420 Code... Need help R3b00T Engine, Exhaust, Transmission 4 07-11-2016 04:18 PM
Code p0420 Patsully3 Issues | Warranty | Recalls / TSB 17 02-26-2016 10:45 PM
