Drives: 2018 BRZ tS
BRZ quick connect vs barb fuel lines
Hi all, my 2018 AUDM BRZ came with barb style fittings on all the fuel lines (see photo 1). Most of the guides on the internet already had quick fit type connectors on their fuel lines.
So when I tried to connect my ethanol sensor using all quick fit hardware, it wasn't compatible. You can see the style of fuel fitting in photo 2. Is the quick fit hardware by definition not able to be fit onto the barbs? Has anyone with these types of fittings installed an ethanol sensor? [IMG] 20211107_182607 by P T, on Flickr[/IMG]see barb style fitting 20211107_173654 by P T, on Flickr
Quick connect fittings shouldn't go over a barb. I assume you already tried. The first picture is broken for me, but I'm assuming your flex fuel kit has no ends that aren't occupied with a fitting. If you can return the fuel lines and build your own, that would be ideal. If not, it's possible you could remove the fittings and attempt to simply clamp the hose on like it was from the factory.
Alternatively you could cut the end of that Barb off to expose a longer length of smooth tube for your quick connect to seat on. However this would require you to pull off the fuel rail or employ some other means to back flush the tube to clear the metal chips/dust Sent from my ONEPLUS A5010 using Tapatalk |
Drives: 2018 BRZ tS
Thanks, I'll have to go for barb fittings and rubber hose!
Let this be a warning for anyone looking for fittings to do ethanol! |
#4 | |
Drives: Q5 + BRZ + M796
Hotwin Nylon Fuel Line Quick Connect Release Disconnect Hose 6.30mm SAE1/4" 6mm https://www.amazon.com/dp/B07KJQ4R4G...ing=UTF8&psc=1
I guess the AU version has different lines there? Was this new or modified prior to you buying?
I seen it on Euro cars too. It is a factory thing from some markets.
Drives: 2018 BRZ tS
Drives: 2018 BRZ tS
| Tags |
| fuel, fuel line |
| fuel line quick connect missing? | pt1878 | Engine, Exhaust, Transmission | 8 | 10-03-2021 10:35 AM |
| Fuel Lines: OEM Hard lines into LS fuel rail | Sportsguy83 | Engine Swaps | 22 | 06-29-2020 12:18 PM |
| FS: Delicious tuning flex fuel black stainless steel braided fuel lines | iceblaze | Southern California | 0 | 09-12-2019 03:36 PM |
| Fuel system questions. Boost-A-pump/stock fuel lines for engine swap | Toxicmilk45 | Engine, Exhaust, Transmission | 4 | 12-14-2015 03:52 PM |
| Direct injection quick connect fuel line part number? | post_break | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 03-31-2014 08:12 PM |
