Old 11-07-2021, 03:20 AM   #1
pt1878
Drives: 2018 BRZ tS
BRZ quick connect vs barb fuel lines
Hi all, my 2018 AUDM BRZ came with barb style fittings on all the fuel lines (see photo 1). Most of the guides on the internet already had quick fit type connectors on their fuel lines.
So when I tried to connect my ethanol sensor using all quick fit hardware, it wasn't compatible. You can see the style of fuel fitting in photo 2.
Is the quick fit hardware by definition not able to be fit onto the barbs?
Has anyone with these types of fittings installed an ethanol sensor?
[IMG]20211107_182607 by P T, on Flickr[/IMG]
see barb style fitting
20211107_173654 by P T, on Flickr
pt1878 is offline   Reply With Quote
Old 11-07-2021, 09:15 AM   #2
Ashikabi
Ashikabi's Avatar
Quick connect fittings shouldn't go over a barb. I assume you already tried. The first picture is broken for me, but I'm assuming your flex fuel kit has no ends that aren't occupied with a fitting. If you can return the fuel lines and build your own, that would be ideal. If not, it's possible you could remove the fittings and attempt to simply clamp the hose on like it was from the factory.
Alternatively you could cut the end of that Barb off to expose a longer length of smooth tube for your quick connect to seat on. However this would require you to pull off the fuel rail or employ some other means to back flush the tube to clear the metal chips/dust
Sent from my ONEPLUS A5010 using Tapatalk
Old 11-08-2021, 04:56 AM   #3
pt1878
Drives: 2018 BRZ tS
Thanks, I'll have to go for barb fittings and rubber hose!
Let this be a warning for anyone looking for fittings to do ethanol!
Old 11-10-2021, 11:45 AM   #4
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Maybe you can convert your bare hose ends to quick connect ends with an appropriate size adapter.
Hotwin Nylon Fuel Line Quick Connect Release Disconnect Hose 6.30mm SAE1/4" 6mm https://www.amazon.com/dp/B07KJQ4R4G...ing=UTF8&psc=1
Old 11-11-2021, 09:40 PM   #5
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
I guess the AU version has different lines there? Was this new or modified prior to you buying?
Old 11-12-2021, 01:30 AM   #6
Irace86.2.0
I seen it on Euro cars too. It is a factory thing from some markets.
Old 11-13-2021, 12:15 AM   #7
pt1878
Drives: 2018 BRZ tS
definitely all stock lines. I guess some people have quick connect, some people have barbs. The majority of DIY's on youtube have the quick connects
Old 11-13-2021, 12:17 AM   #8
pt1878
Drives: 2018 BRZ tS
I ended up just using push on hoses. I do have barb to quick connect adapters for the ethanol sensor
fuel, fuel line
fuel line quick connect missing? pt1878 Engine, Exhaust, Transmission 8 10-03-2021 10:35 AM
Fuel Lines: OEM Hard lines into LS fuel rail Sportsguy83 Engine Swaps 22 06-29-2020 12:18 PM
FS: Delicious tuning flex fuel black stainless steel braided fuel lines iceblaze Southern California 0 09-12-2019 03:36 PM
Fuel system questions. Boost-A-pump/stock fuel lines for engine swap Toxicmilk45 Engine, Exhaust, Transmission 4 12-14-2015 03:52 PM
Direct injection quick connect fuel line part number? post_break Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 03-31-2014 08:12 PM
