Old 09-30-2021, 07:11 AM   #1
pt1878
Drives: 2018 BRZ tS
fuel line quick connect missing?
I've been seeing everyone else with the green plastic quick connect fuel adapters
Does anyone know why my car doesn't have it? Is this normal? My one is a 2018 Aus model.
Also, does anyone have an opinion on which line to connect to a flex fuel sensor? I've seen people use the top line and the bottom line
20210930_210118 by P T, on Flickr
pt1878 is offline   Reply With Quote
Old 09-30-2021, 07:20 AM   #2
Ashikabi
Ashikabi's Avatar
That's how mine was too (2013)
Old 10-01-2021, 11:58 AM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That is the return I believe, not under as much pressure.
Old 10-01-2021, 12:45 PM   #4
Ashikabi
Ashikabi's Avatar
There is no return. OE fuel systems deadhead at the rails
Old 10-01-2021, 12:52 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah, you are right. I miss read one of the other diagrams of the fuel system I was looking at, I thought it showed a return. Looking again I believe the line without the QD is the feed to the lift pump since it is not under as much pressure.
Old 10-02-2021, 09:30 AM   #6
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
This quote from Radium Engineering refers to a return line. What are they referring to?
The kit also includes a vehicle-specific contoured billet aluminum collector box. There are two 1" check valve balls incorporated on the tank that serves as trap doors keeping the pump(s) supplied dynamically with fuel during aggressive driving. Furthermore, all returning fuel from the pressure regulator return and the crossover hose enter the collector box through a one-way duckbill valve keeping it full. The duckbill valve prevents back flow and reduces noise from fuel spray. The collector box also permits a mounting solution for the OEM fuel level sender.
Old 10-02-2021, 09:42 AM   #7
Ashikabi
Ashikabi's Avatar
Aftermarket fuel pump hanger for return fuel system
I have an LS swap in my car running stock fuel pump hanger/pressure regulator and stick hardlines. I Teed the front and rear hardline on the engine bay. Capped the middle(evap). There is definitely no return line in the car. Excess fuel pressure is dumped before it enters the hardline
Old 10-03-2021, 09:52 AM   #8
blsfrs
blsfrs's Avatar
Yours system is modified. Radium makes it sound like their set up works with a stock configuration.
Old 10-03-2021, 10:35 AM   #9
Ashikabi
Ashikabi's Avatar
No. Using their fuel pump hanger will actually make the system more modified than what I'm using. I have an aftermarket pump, and aftermarket lines connecting the stock hardlines to aftermarket rails and injectors. But the system operates as if it was stock. The Radium basket replaces the stock fuel pump hanger. This requires you to replace the pump and adapt the system to a return type. You'll need a different fuel rail(so it has a return), a fuel pressure regulator, and a return line. Then you have to bypass the stock fuel pump controller. You're replacing the entire system with one that functions differently. No modern car, from the factory, has a return fuel system and hasn't for... Decades? Maybe a supercar would. Maybe
fuel, fuel line
Quick fuel line question Ashikabi Engine, Exhaust, Transmission 10 09-17-2021 06:56 AM
Quick shifting technique that minimizes drive-line lash? brillo Engine, Exhaust, Transmission 14 07-14-2017 04:19 PM
WTB OEM Fuel Line #maverick# Want-To-Buy Requests 0 06-03-2015 02:33 AM
Am I missing something (fuel consumption vs performance vs weight) GRoss FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 33 09-23-2014 03:34 PM
Direct injection quick connect fuel line part number? post_break Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 03-31-2014 08:12 PM
