Old 10-30-2021, 02:49 AM   #1
Firedrops
Drives: MY15
Full Pinout for D29 Unused 6 Pin behind the Headunit?
Previously mentioned in
  1. Old Thread
  2. The electrical manual
But none of them have full pinout, most just the location. Maybe the manual does, but I'm not sure how to find/read that part.
In the below photo attached, according to the Youtube video,
  • 4 = ACC 12 V
  • 6 = Always On 12 V
but all the rest are unknown.
Would really appreciate it if anyone has more information, especially on the Ground pin, if it has one
Firedrops is offline   Reply With Quote
Old 10-30-2021, 12:31 PM   #2
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
  1. Old Thread
  • 4 = ACC 12 V
Instead of just watching the video, continue on with reading the thread that you have also provided. A few posts down, somebody explains what they are.
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 10-30-2021, 11:34 PM   #3
Firedrops
Drives: MY15
Thanks, can't believe I missed that!
By matching with the photos in that thread, think this should be right?
  • 1 = Unused?
  • 2 = CAN bus
  • 3 = CAN bus
  • 4 = ACC 12 V (Radio fuse)
  • 5= Ground
  • 6 = Always On 12 V (Dome light fuse)
Old 10-31-2021, 01:35 PM   #4
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
  • 1 = Unused?
  • 2 = CAN bus
  • 3 = CAN bus
  • 5= Ground
We'll be relying on you and your expert diagnosing skills to confirm.
Old 12-12-2022, 03:35 AM   #5
Firedrops
Drives: MY15
"expert" diagnosing skills back to report... I think I got them mirrored in my previous post. There is indeed one unused pin in one extreme end, that side is the one with the ground pin. The other extreme end has always-on-12V on the same level as the ground pin, and acc-12V just above/below it.
Old 03-02-2023, 06:06 PM   #6
Luns
Drives: 2017 GT86
  1. The electrical manual
It's on page 364 of the wiring manual you linked to.
  • 1 = Unused?
  • 2 = CAN bus
  • 3 = CAN bus
  • 5= Ground
You numbered your pins in the reverse order from the wiring manual; the index for the connector pins is on page 394. Your pin 1 is officially pin 6, your pin 6 is officially pin1, so forth.
By the manual:
  • 1 always on 12v (Orange)
  • 2 ground (Black-Yellow)
  • 3 accessory 12v (Red-Black)
  • 4 Can H (Pink)
  • 5 Can L (bLue)
  • 6 unused
Luns is offline   Reply With Quote
Old 05-01-2026, 04:44 AM   #7
ft86tr
I tested CAN H and CAN L pins in my EUDM car and the resistance is not 60 ohms. Maybe it is specific to USDM cars
ft86tr is offline   Reply With Quote
Old 05-03-2026, 11:14 PM   #8
tarzan_nojane
tarzan_nojane's Avatar
Drives: 2014 FR-S
By the manual:
  • 4 Can H (Pink)
  • 5 Can L (bLue)
  • 6 unused
This worked for me and I was able to connect my joying and read the TPMS data without any additional module(s).
tarzan_nojane is offline   Reply With Quote
BRZ/FRS/86 ECU Pinout irax Engine Swaps 2 11-12-2020 12:55 AM
ECU PINOUT DIAGRAM HELP! Phoenix_gts86 Electronics | Audio | NAV | Infotainment 12 05-16-2019 10:47 AM
BRZ camera pinout gpvecchi Electronics | Audio | NAV | Infotainment 4 07-27-2018 04:47 PM
FR-S Audio pinout help needed mid_life_crisis Electronics | Audio | NAV | Infotainment 43 01-07-2014 11:18 AM
ECU Pinout? Argento_FR-S Engine, Exhaust, Transmission 5 03-08-2013 10:19 AM
