BRZ camera pinout
I’m trying to retrofit a genuine stock rear camera as in Italy it’s not available. I’d need to know which cables are +6V and ground.
Thanks! |
Certs You Dont Care About
Drives: 2013 Galaxy Blue BRZ
Is the wiring for the camera present in the rear of the car, or did you need to run new wiring? Is this for a stock headunit, or aftermarket?
There is no wiring, so I had to adapt stock camera for aftermarket unit.
FYI, the correct pinout is Red +6V Black ground Yellow video Heat shrinked black video ground |
Just be careful as most aftermarket radios output 12v and require a step down adapter
Yup, you just need a 7806. 1€...
| Automatic gear selector wiring pinout | Scikotic | Engine, Exhaust, Transmission | 7 | 11-17-2016 04:31 PM |
| 100% Plug-&-Play Rearview Camera Installed from camera-source.com (Pics) | zthang | DIY (Do-It-Yourself) Guides | 10 | 12-18-2015 04:14 PM |
| Pinout for FRS Bespoke head unit - video inputs? | ATSAaron | Electronics | Audio | NAV | Infotainment | 2 | 12-09-2014 10:59 PM |
| FR-S Audio pinout help needed | mid_life_crisis | Electronics | Audio | NAV | Infotainment | 43 | 01-07-2014 11:18 AM |
| ECU Pinout? | Argento_FR-S | Engine, Exhaust, Transmission | 5 | 03-08-2013 10:19 AM |
