Drives: 2017 86
Torque damper
I came across a torque damper from a website that sells japanese parts. Looks like a torque damper however, i have not a clue as to where in gods green earth it bolts to. The part makes no sense as these engines dont really move in the same way that others do and its low center of gravity only helps that matter. Im just curious is all. Ive ordered whiteline trans insert and differential bushing inserts to get rid of some of the drivetrain slop. Id be willing to review this so called damper to satiate others interests as well and be a guinea pig. Here is the link:
https://www.rhdjapan.com/silk-road-s...e-zn6-zc6.html Note that some of the photos look like generics of dampers for other jdm vehicles they make them for, but this is labeled specifically for the ZN6 platform aka the gist of this entire forum. Im sure there are better parts that are commonly used to achieve a mild reduction in drivetrain slop. Hence why i went with the inserts first but those are for the rear end of the vehicle im almost positive this attaches to the engine and the chassis somewhere but with turbo goin on under the hood theres not a lot of real estate pending the kit we go with. |
This might help.
https://www.thedailystar.net/shift/s...act-or-fiction Bubba rule of thumb is that if you don't know what it does or where it goes - ya don't need it -
#4 | |
Drives: 2013 frs base
I'd like to see a video of an engine during a hot lap. How much does it actually move? |
Drives: 2018 BRZ
Do note that this appears to also brace the brake cylinder, which requires a mirrored part between right-hand drive and left-hand drive cars. It's not clear from the instructions @gpvecchi posted whether or not that's some additional bracing this kit does or if it's needed to get it to work at all, but I'd be cautious with fitting this on a LHD car.
Señor Member
Our motor moves around a surprising amount from cornering loads as well as torque on the stock mounts. I don't thing there is any problem with that though. Unless it causes something to rub etc
1974 TA22 Celica
2013 86 GT |
Drives: 2014 Ultramarine FR-S
To reduce engine movement, probably better off with something proven like the TRD or STI engine mounts for a mild upgrade, or the Cusco engine mounts for a more hardcore upgrade.
And as @Ohio Enthusiast mentioned, fitting a part intended for a RHD car onto our LHD cars may not work anyway since the engine bays are mirrored. |
LMGTFY
Drives: 13 FRS, 91 Miata
If you want those I also have some fuses to sell you.
Drives: 2017 86
There still isnt anything in the way though the brake booster is on the other side if its mirrored, the engine and chassis are in the same place, right?
#10 |
Drives: 2017 86
My goal is to keep my air filter from rubbing, but all these changes may reduce driveline slop and gain a lil torque in the process. I dont want completely solid just stiffer. Plus my 3 inch overpipe rattles on the frame a little.
#11 | |
Drives: 2017 86
| Engine torque damper ? | Simon99 | Scion FR-S / Toyota 86 GT86 General Forum | 41 | 03-05-2023 10:23 AM |
| Calculate torque when using a crows foot on torque wrench | BirdTRD | DIY (Do-It-Yourself) Guides | 0 | 10-11-2015 04:02 PM |
| FRS VS BRZ Damper (strut) | kilohercas | FR-S / BRZ vs.... | 1 | 09-24-2015 03:19 AM |
| Requested torque and Calculated torque | nickw14 | Software Tuning | 3 | 06-13-2015 04:09 AM |
