Old 10-18-2021, 11:33 AM   #1
jamestemperante
Drives: Subaru BRZ
White flakes in radiator
Hi everyone. I just bought my BRZ last month and I noticed some white flakes inside the radiator near the cap. Does anyone know what might this be? Thanks!
jamestemperante is offline   Reply With Quote
Old 10-18-2021, 07:45 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
probably something to do with using green coolant instead of the subaru super blue that is oem for these vehicles.
your coolant is also running low in the radiator.
flush. refill with the right stuff.
Old 10-18-2021, 08:04 PM   #3
norcalpb
norcalpb's Avatar
It’s from letting the fluid get too low. As @soundman98 said, we only use Subaru super blue coolant round these parts
Old 10-19-2021, 01:12 AM   #4
humfrz
Welcome to our forum, jamestemperante -
I see ol soundman98 set you on the right track -
Old 10-19-2021, 06:18 AM   #5
jamestemperante
Drives: Subaru BRZ
thanks guys for your input!
Old 10-22-2021, 05:30 PM   #6
Grady
Grady's Avatar
Just some gunk build up. As stated above I would recommend going to the Subaru blue coolant. Since you are changing coolant specs I would do a couple of flushes with water to try go get as much of that out as possible. Read up on bleeding the coolant system, not as easy as most.
Old 01-07-2022, 03:44 PM   #7
MikeBrooks
MikeBrooks's Avatar
Drives: subaru impreza 2000
Most likely This is an emulsion, the oil got into the antifreeze. This usually happens when the thermostat gasket leaks or is changed and a small amount is mixed! Since your head was removed, perhaps because of this! After a while, it should settle on the walls of the expansion tank! Take a ride, see what happens next. It was similar on my Dodge, then I needed a cummins intercooler upgrade https://boostyourengine.com/5-9-cumm...ooler-upgrade/ because the oil gets there
MikeBrooks is offline   Reply With Quote
WTB: OEM Radiator, Radiator Fan Assembly, Airbox, Condenser, Washer Reservoir, Winjet Xanatos Want-To-Buy Requests 1 01-05-2016 02:24 PM
Black Flakes in Coolant Reservoir?? John Rambo Issues | Warranty | Recalls / TSB 7 07-15-2015 05:58 PM
Midnight23 White on White Greddy Turbo Kit 275whp ***Evasive Tuned*** Evasive Motorsports BRZ Photos, Videos, Wallpapers, Gallery Forum 18 07-15-2014 10:39 PM
FS: Robispec Radiator (Massive radiator and liquid to liquid oil cooler in one) Sportsguy83 Engine, Exhaust, Bolt-Ons 15 05-27-2014 12:18 PM
