Old 10-16-2021, 02:48 PM   #1
Jstyle
Jstyle's Avatar
Drives: 2020 86
TrackAddict problems
I know it’s not a perfect solution but I tried to use TrackAddict yesterday and my results were all over the place as far as video was concerned on my iPhone. On the second session it started recording out of no where. The third session it literally recorded 8 seconds while I left the pit. The last session it recorded a fraction of a second of video in the pit while I was waiting to leave.
I’m pretty sure every time I hit record while I was waiting to leave the pit and it seems like the results were all over the place as far as what happened.
It recorded the laps in the sense that I could go back through them on the map but I have no idea what I’m doing wrong. Can anyone help?
Jstyle is offline   Reply With Quote
Old 10-16-2021, 05:55 PM   #2
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Are you using an external GPS?
Buddy does with good results using TractAddict.
I tried TrackAddict last time out without an external GPS (just iPhone) and it was up and down like a whores drawers. External GPS for next season.
Muskoka800 is offline   Reply With Quote
Old 10-16-2021, 06:13 PM   #3
Jstyle
Jstyle's Avatar
Drives: 2020 86
I was using the iPhone GPS but it’s not that it didn’t track each and every lap pretty well. It was the f’in video that never recorded right. So I think it’s a separate issue.
That being said, I’ve been told because of the 1hz refresh rate external GPS definitely helps with accuracy/
Old 10-22-2021, 12:24 AM   #4
jflogerzi
jflogerzi's Avatar
Here is the best Combo:
Race Chrono, Qstarz BT-Q818XT 10Hz Bluetooth, and the final piece is OBDLink MX+(you need the more expensive one due to Iphone)
The best part about this setup is Race Chrono can use the can bus data stream and custom PIDs
2013 Series 10 FRS #553
The Following 3 Users Say Thank You to jflogerzi For This Useful Post:
NoHaveMSG (10-22-2021), RT-BRZ (10-22-2021), timurrrr (10-29-2021)
NAV problems? AnalogMan Electronics | Audio | NAV | Infotainment 3 04-14-2020 11:55 AM
OFT Problems Nik Software Tuning 5 05-24-2018 09:20 PM
Buddy Club Race Spec Coilover Problems on Problems on Problems mpross Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 09-04-2016 11:18 PM
ECU problems cwilson Issues | Warranty | Recalls / TSB 4 04-14-2016 10:01 PM
Transmission problems, oil leaks and detonation problems.. turboviper Issues | Warranty | Recalls / TSB 4 06-18-2014 04:01 PM
