Old 05-23-2018, 06:58 PM   #1
Nik
Drives: 1988 Toyota Supra Turbo, 2016 FRS
Unhappy OFT Problems
So a few days ago we got my turbo kit installed and running on a base tune from Shiv. Everything was running good until last night as I was leaving a parking lot the car decided to turn itself off while driving. I tried to start it again but the car wouldnt crank. I then tried to read the ECU Fault codes but my OFT said it couldnt communicate with my ECU. I then tried to reflash my tune onto the ECU again the OFT kept telling me to turn key to ON position and press ok but would say that twice and then give me an error. Any ideas? Im not sure why all of a sudden my ECU would freak out.
Nik is offline   Reply With Quote
Old 05-23-2018, 07:52 PM   #2
steve99
can you read DTC codes from ecu ?
Old 05-23-2018, 08:17 PM   #3
Nik
Im kind of a noob to all this, what are DTC codes?
Old 05-23-2018, 10:25 PM   #4
steve99
Diagnostic trouble codes also try reading ecu info for will tell you if you have any connection to ecu
Old 05-24-2018, 03:53 AM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
Do you get any electrics on at all? What happens when you try and crank it over?
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-24-2018, 09:20 PM   #6
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
What mods do you have installed?
You say in the OP that it won't crank... people always get the terminology wrong, so clarify- it won't crank as in you turn the key and engine won't turn over (no crank, no start), or it turns over but will not start (crank, no start)? Exactly what noises do you hear when you turn the key?
oft, sbd, tune, tuning, turbo
2jz problems Diz86x Engine Swaps 1 11-14-2016 02:29 AM
Buddy Club Race Spec Coilover Problems on Problems on Problems mpross Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 09-04-2016 11:18 PM
AT problems? AJPG Engine, Exhaust, Transmission 8 03-08-2015 06:50 AM
Transmission problems, oil leaks and detonation problems.. turboviper Issues | Warranty | Recalls / TSB 4 06-18-2014 04:01 PM
A few problems...but how bad are they? deedz Issues | Warranty | Recalls / TSB 20 07-21-2013 02:27 AM
