Old 10-07-2021, 06:47 PM   #1
DoubleAKash
Drives: 2019 Subaru BRZ - JDL Turbo Kit
Replacing OEM Brembo Brake Pads
Hi All,
So I've been searching around and found the subaru part numbers for the OEM brake pad replacement however has anyone know or found the brembo pad replacements?
For the front I've found: https://www.brembostoreusa.com/produ...ad-set/P54039N
And for the back: https://www.brembostoreusa.com/produ...ad-set/P56048N
Wondering if anyone has purchased these straight from brembo, seem to be much much cheaper than Subaru Parts
DoubleAKash is offline   Reply With Quote
Old 10-07-2021, 06:58 PM   #2
Code Monkey
Drives: Subaru BRZ
Try KNS Brakes for a variety of choices.
Code Monkey is offline   Reply With Quote
Old 10-11-2021, 08:02 AM   #3
Espi
Espi's Avatar
Drives: 17 BRZ
Any WRX STI pad is compatible. i went with Stoptech sports pads. Last long, good for daily and spirited drives on the mountain with no fade.
Espi is offline   Reply With Quote
Old 10-18-2021, 10:34 PM   #4
jflogerzi
jflogerzi's Avatar
Lotsss of good options out there.
Sent from my Pixel 5a using Tapatalk
2013 Series 10 FRS #553
Old 10-19-2021, 05:38 PM   #5
Originally Posted by DoubleAKash View Post
Hi All,
FYI that is not the OE pad. It's just a cheap OE shape pad. You'll have vastly decreased braking performance with the pad you linked, compared to OEM.
Old 10-19-2021, 06:18 PM   #6
DoubleAKash
Hi Mike, what would you recommend to be a good brembo brakes OEM like replacement for street use. Also would the rotors also need to be changed as well. Currently the car is sitting at 25k miles and really only use it as a daily driver
Old 10-19-2021, 07:08 PM   #7
If you don't mind the loss in braking power, you can use the pads you linked.
Centric rotors on a budget.
If you like the factory pads, then get the actual factory pads.
OEM rotors are fantastic in metalurty and life. I'd be surprised if you actually need new rotors. Double check before you throw money away for no reason.
If you want to go OE+ for street use, check out the CSG CP. More response, less dust.
FS: OEM Brembo Brake Pads for BRZ Performance Package Brakes (From new 2020 car) abyssFT86 Brakes, Suspension, Chassis 2 04-15-2021 08:39 AM
FS: OEM wheels, HAWK HPS front and rear brake pads, OEM brake pads, TYC colins tails oppiee Canada Classifieds 4 10-07-2019 05:27 PM
Have anyone tried these Brembo brake pads for stock brakes? OG5874 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 06-11-2019 01:27 PM
2017 BRZ OEM Brembo brake pads -- SOLD Code Monkey Brakes, Suspension, Chassis 21 07-17-2018 07:43 AM
Replacing Pads without doing the rotors robtan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 07-29-2014 10:59 PM
