Old 06-03-2019, 03:41 AM   #1
OG5874
Drives: 2015 Scion FR-S
Have anyone tried these Brembo brake pads for stock brakes?
Brembo makes pads for stock 86 and brz, Brembo P78018N(Rear) and Brembo P78021N(Front). Have anyone tried these out yet? They are cheaper than oem toyota brake pads so i might try them out.
OG5874 is offline   Reply With Quote
Old 06-03-2019, 04:08 AM   #2
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
If your stock brake pads need replacing, they're probably fine. They're not going to make the brakes work any better, though. Street pads are street pads.
Old 06-04-2019, 02:40 PM   #3
AutoNewb
Drives: 2014 Subaru BRZ Sterling Silver
Curious about this as well... they are very inexpensive. How good are they? I mean... they are Brembo. They must be good, right?
AutoNewb is offline   Reply With Quote
Old 06-04-2019, 03:01 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Good is subjective. Adequate is a better word. Fine replacement for stock if stock brakes were suiting you well enough
The Following User Says Thank You to DarkPira7e For This Useful Post:
strat61caster (06-04-2019)
Old 06-05-2019, 02:08 AM   #5
OG5874
Even if they are a little better than stock thats fine for me since i dont track my car. Im debating on these or the stoptech sports pads.
Old 06-05-2019, 03:17 AM   #6
EAGLE5
Dismember
EAGLE5's Avatar
You keep choosing WTF options. Do you want to go on track? Neither of these choices nor OEM will cut it. Do you want street driving with a bit more bite? I suppose the stoptechs might provide it, maybe. Probably with more noise. Want to throw some pads on and forget about it? I like my PFC pads. Ultramaroon liked them too. Tons of bite cold, way more than stock, and capable of anything the stock braking system can handle at the track.
Old 06-05-2019, 11:26 AM   #7
OG5874
i dont know what is so wtf about my choice? They are both street pads that are about the same price as oem pads. Also i stated that i wont be tracking with them its only for DD and some hard canyon runs. I just wants pads that are better than oem for the price range of $150 for a set of front and rears. Also dont want to run track pads on the street, im not about that life lol.
Old 06-05-2019, 11:33 AM   #8
EAGLE5
Dismember
EAGLE5's Avatar
What does better than OEM mean? I don't see how any of these will be better. Maybe slightly different. Maybe more grabby, possibly less dust, and definitely more noise.
The Following User Says Thank You to EAGLE5 For This Useful Post:
wparsons (06-06-2019)
Old 06-05-2019, 12:05 PM   #9
Dorkhedeos
Drives: 2015 BRZ
I don't know what you mean by better, but Akebono pads are pretty much OEM at around $120 shipped for 4 corners.
They will all stop your car in the same distance since you will most likely be grip limited on street tires. Sport pads will give you more bite, but generally are louder, dust more, and wear your rotors down faster.
Dorkhedeos is offline   Reply With Quote
Old 06-06-2019, 03:11 AM   #10
OG5874
Ya i guess i should have been more specific on what i wanted, what i meant by better was just more bite, dont really care for brake dust and noise(not track pads though those are too loud). Also brake fade shouldnt really be a problem since i never got that with oem pads on the street.
Old 06-06-2019, 04:40 AM   #11
EAGLE5
Dismember
EAGLE5's Avatar
Get a semi-metallic pad.
Old 06-07-2019, 11:28 AM   #12
Rabidpug
Rabidpug's Avatar
Drives: 2017 BRZ Limited
Got a link for the PFC pads you like?
Rabidpug is offline   Reply With Quote
Old 06-11-2019, 12:31 PM   #13
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Winmax W2s are a brilliant street pad. Worlds better than sock with zero drawbacks of an aggressive pad. More bite, better pedal feel, and less fade. Huge simple cheap upgrade.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
The Following User Says Thank You to Hyper4mance2k For This Useful Post:
ichitaka05 (06-11-2019)
Old 06-11-2019, 01:27 PM   #14
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
I, 2nd Winmax W2. Very nice setup... maybe lil too soft for Autox or track use, if you really serious bout autox. Casual autox is def fine. Some might complain that, it's more dusty than stock... but it's very small amount compare to other brands.
brake pads, brembo
2017 BRZ OEM Brembo brake pads -- SOLD Code Monkey Brakes, Suspension, Chassis 21 07-17-2018 07:43 AM
Brembo: GT, GT-R, Club Sport Brakes, AP Racing BBK & Agency Power Brake & Clutch Line eauto Brakes, Suspension, Chassis 361 10-15-2014 01:43 PM
Brembo Front Brakes, APR Brake Ducts, GT Spec Rear Lower T Brace/Sway Brace, etc smellslikecurry Brakes, Suspension, Chassis 27 08-15-2014 11:52 AM
FS: Carbotech Performance Brakes, CT929-XP10 (Subaru BRZ/Toyota FRS) Front Brake Pads xman11 Brakes, Suspension, Chassis 3 10-04-2013 02:23 AM
What's everyone doing on stock brakes, for pads? Nourdmrolnmt1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 05-15-2013 05:08 PM
