Old 09-29-2021, 10:50 AM   #1
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ
Aspect ratio - 16” wheels
Hello,
What are the highest aspect ratio that can be used in 16” 205 and 215 tires?
From the wheel size calculations, I saw recommended 215/55 and 205/60, but I would like q little bit more ground clearance for winter (and also for the fun of trying a different route for winter driving)
Anyone tries anything bigger than those? 70 ?
How much the scrub radius is affected?
I will try this on the 22 BRZ, but any feedback from a stock-ish gen1 would be really appreciated.
Stonehorsw is offline   Reply With Quote
Old 09-29-2021, 10:53 AM   #2
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Depends on wheel width.
I have a set of 16x7 +50 with 205/55R16 and had no clearance issues on fully stock suspensionl/alignment.
The Following User Says Thank You to RToyo86 For This Useful Post:
Stonehorsw (09-29-2021)
Old 09-29-2021, 11:36 AM   #3
Stonehorsw
Stonehorsw's Avatar
Good point. How about the ground clearance, did you gain any? And did you see any weirdness on the steering behavior and straight line stability?
I am using the wheel-size website. Seems good from first look.
https://www.wheel-size.com/calc/?whe...cl=50mm&sr=0mm
Old 09-29-2021, 12:02 PM   #4
RToyo86
RToyo86's Avatar
205/55R16 is slightly taller than 215/45r17 but not by much. I did not get any weird behavior as a result of the taller sidewall. Your tire choice will have a bigger impact on stability. Most winters are garage for response/stability due to soft sidewalls.
I recall the cars that were sold in 16" fitment had the same exact tires.
Old 09-29-2021, 01:19 PM   #5
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
The 205/55 R16 tire was the factory size for the low-trim levels in Japan and Europe. One-make series races in Japan used the same spec too.
About what aspect of your writing are you the most insecure? Ultramaroon Off-Topic Lounge [WARNING: NO POLITICS] 32 09-14-2015 12:15 PM
My Favorite aspect of the FR-S/BRZ jflogerzi Scion FR-S / Toyota 86 GT86 General Forum 9 09-10-2012 06:09 AM
Best method to order/purchase car? Finance aspect? Insurance? Buggy51 Other Vehicles & General Automotive Discussions 28 04-23-2012 07:48 AM
I will tell you one aspect of BRZ ownership I am NOT looking forward to Lighting Red BRZ First-Gen (2012+) — General Topics 76 04-02-2012 10:15 AM
FR-S to BRZ Ratio MannyO New England 11 03-08-2012 02:23 AM
