Old 09-25-2021, 09:33 PM   #1
macuser27
macuser27's Avatar
Check Engine P300, P302, P303
Did a track day last week and the check engine light came on during the third session.
Car starts up and idles fine, drives fine, feels and sounds normal. Drove it home from the track with no issues. Pulled codes P300, P302 and P303.
I drove it today, around 80 miles with no issues. Check engine light did not go away. Codes are the same P300, P302 and P303.
Car is a 2013 with 71,xxx miles on the chassis and 11,xxx miles on replacement engine.
What are the next steps? Replace coil packs in cylinder 2 and 3?
macuser27 is offline   Reply With Quote
Old 09-26-2021, 12:19 AM   #2
p1l0t
p1l0t's Avatar
Ummm P0300?
Old 09-26-2021, 01:01 AM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
You just read the codes, but didn't erase them?
Codes are stored in the computer until a certain amount of drive cycles are completed. I don't know the number, but it's a lot, so even driving the car every day for 2 hours for a week isn't going to clear the codes by itself.
So all the codes deal with misfires.
First step would be to erase the codes, and see if they come back.
Second step would be to run a different tank of gas through the car.
How full was the gas tank on the last session?
Don't be throwing parts at a problem until you know you definitely have a problem and not a oddball one-off situation.
At least, that's the rule of thumb for most people with finite amounts of income. If you've got entire banks of money to burn, just start throwing parts at it until it goes away
Old 09-26-2021, 02:22 PM   #4
macuser27
macuser27's Avatar
Thank you.
Correct. I read the codes but not erase them. I'll do so and report back if the codes reappear.
I arrived at the track that morning with a full tank of Shell Premium (91 octane here in CA). I noticed the check engine light at the end of the third session. The fuel level indicator was around 1/4 tank. I brimmed the tank with Sunoco 91 octane at the track for the 4th (last) session and drive home.
I agree with you at not throwing parts at the problem. My mind went straight to coil packs as #2 and #3 (and #4) are at 71,xxx miles. Coil pack #1 was replaced at 25,xxx miles and again at 50,xxx miles based on the previous owner's service log. I'll hold off for now and continue the diagnosis. Thanks again.
Old 09-26-2021, 05:19 PM   #5
soundman98
soundman98's Avatar
also be sure to check the fuel injector module bolts on the passenger side of the motor. some of those are used as grounds, and if they become loose, it'll result in engine run errors. i believe failure for the injectors to fire and inject fuel would also create a misfire situation.
it just strikes me as odd that 1 injector has 'failed' twice in 25k mile increments, and now you're experiencing a pair of cylinder problems at the next 25k mile increment?
lots of coincidences in that. parts generally don't fail that close to a predicable pattern over the course of 75k miles.
thinking broadly, there are a number of guys that experience fuel starvation on high-g turns. left-hand i think? i know verus sells a modified fuel flap door specifically for the purpose. but this is going to depend on the specific turns of the track you're running, and should be very predictable(should always happen on 'turn x' to determine if that would be the cause.
Old 09-26-2021, 10:36 PM   #6
Turdinator
Señor Member
Turdinator's Avatar
Misfires when tracking aren't an unusual thing. Do you have a tune on the car? Sometimes that will contribute. Replacement coils are the best way to fix it but you can also swap the coils that didn't misfire over with the ones that did and get a bit longer out of them before you need to replace them (since the coils ain't cheap)
1974 TA22 Celica
2013 86 GT
Check engine light then a traction control light then just a check engine... and then Jstyle Issues | Warranty | Recalls / TSB 13 02-15-2021 05:10 PM
Help! From check engine light to fouled plugs back to check engine + plugs refouling larchamb Issues | Warranty | Recalls / TSB 44 04-03-2016 09:39 AM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 06:06 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
