Old 09-11-2021, 04:37 PM   #1
shlr
Drives: 2017 Subaru BRZ
Using 12V to the 6V OEM reverse camera?
This may be a dumb question but I just got a new aftermarket headunit and I believe it has 12V output for the reverse camera. I have a 2017 BRZ with an OEM reverse camera which only needs 6V.
Will using the 12V fry my camera/do I need to get a 12V to 6V converter?
shlr is offline   Reply With Quote
Old 09-11-2021, 11:05 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
yes, you NEED the 6v converter. 6v can go into a 12v camera, no problem, but 12v will fry a 6v camera, and cost to replace...
Old 09-12-2021, 01:18 PM   #3
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Absolutely need to reduce the 12V down to 6V. Something like this would work:
https://www.amazon.com/Proshopping-C...dp/B07XSFKRMK/
LimitedSlip is offline   Reply With Quote
Old 09-25-2021, 04:36 PM   #4
shlr
Is there a guide to wire the converter?
Old 09-25-2021, 04:57 PM   #5
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
It’s printed on the converter. 12v goes in the red/black side, 6v comes out the yellow/black side.
12v, headunit, reverse camera
Help with reverse camera melvin_213 Electronics | Audio | NAV | Infotainment 23 05-19-2020 11:23 PM
Need help with installing Camera Source's reverse camera for 2013 FRS Ann13 DIY (Do-It-Yourself) Guides 9 09-30-2019 07:39 PM
Reverse Camera Emissary_of_Pain Electronics | Audio | NAV | Infotainment 5 10-27-2017 10:13 AM
FYI - it's possible to add a reverse camera for $20. SloS13 Electronics | Audio | NAV | Infotainment 25 09-09-2013 10:03 PM
Reverse Camera FT86_Zero Scion FR-S / Toyota 86 GT86 General Forum 26 08-05-2012 08:05 PM
