Old 10-19-2017, 04:50 PM   #1
Emissary_of_Pain
Emissary_of_Pain's Avatar
Drives: Toyota GT86 Limited Edition
Reverse Camera
Good Day,
Sorry if this has already been posted, but I tried searching the forum but had no luck ... I blame it on my tablet
I was curious how easy it is to install a reverse camera ? ... I see they are really cheap on ebay and I know it would make my wife's life a lot easier as she parks in town where it is pretty crowded.
Regards
Emissary_of_Pain is offline   Reply With Quote
Old 10-19-2017, 05:05 PM   #2
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
http://www.ft86club.com/forums/showthread.php?t=17020
One of a dozen or so threads... Hint: use google to search and not the forum search feature
P.S. Welcome!
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
Old 10-19-2017, 05:16 PM   #3
Emissary_of_Pain
P.S. Welcome!
Thanks very much ... I really appreciate it.
And thanks for the forum greet
Old 10-26-2017, 11:05 PM   #4
rapacigila
Drives: Man
Reverse Camera
Ok just tried my above mentioned combination and it didnt work. Really going to need a pin out or wiring diagram for bmw reverse parking camera if anyone can help?
rapacigila is offline   Reply With Quote
Old 10-27-2017, 09:28 AM   #5
nextcar
Is your camera 6volt or 12volt? Stock head unit only supplies 6volts, you may need a solenoid/relay. You must power the camera from the head unit- it will supply power at start for a couple seconds and look for video signals to enable the display. Once this happens it will turn the camera off and then use the reverse signal to control the camera and display. If the camera output is not present at head unit startup it will not work
Pull out
Old 10-27-2017, 10:13 AM   #6
sweetpea
sweetpea's Avatar
I got the one from Amazon for $150. It came with the wiring harness and Camera for a 2014 BRZ. It was super simple to install (did require drilling a hole in the trunk though). Works flawless.
Takes about 1-2hrs to run all the wiring and make it look clean. I cut the white cord on the camera so I didn't have double lines on the camera view. You can also go into the headunit calibration screens and move the lines manually there so they line up. Again, all easy to do.
sweetpea is offline   Reply With Quote
reverse camera wiring derka-derka Electronics | Audio | NAV | Infotainment 14 06-16-2015 03:09 AM
FS: Subaru BRZ OEM Reverse Camera Euro7R Canada Classifieds 1 05-06-2015 04:25 PM
FYI - it's possible to add a reverse camera for $20. SloS13 Electronics | Audio | NAV | Infotainment 25 09-09-2013 10:03 PM
Reverse Camera FT86_Zero Scion FR-S / Toyota 86 GT86 General Forum 26 08-05-2012 08:05 PM
Reverse camera? dorkymork BRZ First-Gen (2012+) — General Topics 28 05-21-2012 10:21 AM
