Old 09-03-2021, 04:55 PM   #1
Leviticus Ezra
Leviticus Ezra's Avatar
Drives: 2017 BRZ w/Performance Package
Question Intake line for 3 port EBCS?
Hey guys,
Nearing the completion of my turbo build and want to make sure I have my thinking straight. If I want to utilize all three ports on an EBCS, the 3rd port should be coming from the line off the intake? If so, do I snag a T fitting and splice the line and I'm good to go?
Thank you!
Leviticus Ezra is offline   Reply With Quote
Old 09-05-2021, 07:32 PM   #2
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
keep it simple
Old 09-06-2021, 01:18 AM   #3
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
There are two ways of running the controller. You can run it like running a manual boost controller to bleed off boost. The top of the wastegate is vented to atmosphere. A hose is run from the turbo to the “bottom”/side of the wastegate normally, but the EBC sits in between and bleeds off boost to atmosphere just like a manual boost controller. The difference is the amount of control to do boost by gear or whatever.
The better way to route the EBC is to run a line to the top of the wastegate from the solenoid and then have another go to the “bottom”/side of the wastegate, and this can be done in a few different configurations.
I believe people can also choose to run two lines instead of teeing off a line from the turbo. One line would be off the turbo to the “bottom”/side of the wastegate or to the solenoid. The second line would be off the intake manifold to the “bottom”/side of the wastegate or to the solenoid.
A third way is like the picture above with a tee, but the source is the intake manifold instead of the turbo.
Old 09-06-2021, 03:08 AM   #4
Irace86.2.0
Advantages of the first way is simplicity.
Advantages of the second way is that pressure is being used to keep the wastegate closed, so it doesn’t crack before reaching the target boost. This translates to faster spool, and thus, there is more area under the curve with more low end torque. The disadvantage is complexity.
The advantage of going off the turbo instead of the intake manifold is better wastegate response, so less chance of boost spike, where going off the manifold there is overboost because of a slight delay to open the wastegate. The disadvantage historically has been needing to tap the turbo compressor or charge pipe, so people just teed into the intake manifold.
The advantage of venting the wastegate and/ solenoid to atmosphere is simplicity. The advantage of routing it back to the intake is for emissions for the air to get consumed after being contaminated with fuel/oil vapors circulating through the intake/turbo, and routing it to the intake means there is less chance of unfiltered air clogging the port or getting into the solenoid.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Krazyyykevin (09-07-2021)
boost control, forced induction, intake, turbo, vaccum lines
Searching For a replacement USB port for the factory port for aftermarket radio Kutanks Electronics | Audio | NAV | Infotainment 20 08-21-2021 09:12 PM
18% STFT WITH NO VACCUM LEAK Kris86 Software Tuning 0 05-22-2017 02:43 PM
New Product Release! Infamous Performance 3 port EBCS! BRZ/FRS specific! Plug & play! Infamous Performance Forced Induction 28 11-13-2014 01:51 PM
New Product Release! Infamous Performance 3 port EBCS! BRZ/FRS specific! Plug & play! Infamous Performance Forced Induction 11 08-04-2014 08:28 PM
Tapped Oil Pan whitefrs Forced Induction 17 08-29-2013 02:40 PM
