Old 02-25-2013, 08:50 AM   #1
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Tapped Oil Pan
Are any vendors planning on selling tapped oil pans, so we dont have to weld out oem oil pan.
Old 02-25-2013, 09:41 AM   #2
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
Buy new OEM pan. Bring pan with fitting to a local shop. Profit.
No Limit Motorsport is offline   Reply With Quote
Old 02-25-2013, 11:20 AM   #3
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Do u guys do this?
Old 02-25-2013, 11:36 AM   #4
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
What do you need the tapped pan for? Gauge or turbo drain? If gauge, just buy a drain plug that doubles as an adapter to mount the sensor in.
Otherwise, the cheapest/easiest option is to drop the pan and weld in a bung.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-25-2013, 12:13 PM   #5
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
You don't need to tap it at least for the Full Blown kit. It isn't really thick enough to tap anyways. You just need to drill it and then weld on the AN fitting for the oil return. Mine actually has a pipe that goes from the edge of the pan to the front of the motor where the AN fitting is welded on the end of the pipe. By the way new oil pans are around $100. I would recommend getting one and having the welding done in advance so it doesn't delay your install and you can easily return to stock should you decide to sell your kit.
Old 02-25-2013, 12:17 PM   #6
No Limit Motorsport
Do u guys do this?
Yes we do. However you either need to show us where to mark it, or you need to wait until we install our Full Blown kit on our car (hopefully about 1 month) so we know where to weld it.
Old 02-25-2013, 12:28 PM   #7
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
I highly recommend mocking up your drain on the car, marking the pan, drilling it, test fitting it and then getting it welded. The wrong angle and it will hit the block, the water pump, or be at an angle that doesn't promote proper drainage.
Not to mention, oil pans are on intergalactic backorder from Japan right now, I ordered a spare to have in stock, took 2 months to get and was supposedly 1 of 3 in the country.
Pure Automotive is offline   Reply With Quote
Old 02-25-2013, 12:58 PM   #8
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Well i think having a spare one is always a good choice
@Nolimitmotorsports
Im goin with the full blown kit, im gonna order it soon
Old 08-29-2013, 09:31 AM   #9
shiro
shiro's Avatar
Drives: 2013 Scion FR-S, 2014 Lexus IS350
Hey Guys,
Getting ready to tap my oil pan in a couple weeks for my Greddy Turbo Kit. The kit comes with regular Goodyear tubing that is pushed on. Would it be better to upgrade the hose to use AN fittings, weld a threaded bung and use a braided hose? Thanks!
shiro is offline   Reply With Quote
Old 08-29-2013, 10:03 AM   #10
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Originally Posted by shiro View Post
Hey Guys,
I think better is debateable. It would be nice to have the assurance that there is no way the hose is coming off with the AN fittings, but I can tell you the OEM Subaru WRX/STI drain return line is just a rubber hose with the weakest hose clamps ever holding it on the turbo and the block. I probably wouldn't worry about upgrading it.
Old 08-29-2013, 10:22 AM   #11
shiro
shiro's Avatar
Thanks! I appreciate the feedback!
Old 08-29-2013, 10:35 AM   #12
ft_sjo
Drives: GT86
As long as the fitting is swaged, then you shouldn't have a problem. Like so:
(not an FA20 sump/pan, of course)
Old 08-29-2013, 01:00 PM   #13
kanundrum
Drives: 2013 Whiteout FR-S
From Ptuning
Originally Posted by ptuning View Post
A few more goodies have now been completed.
Our CNC machined, anodized, billet aluminum turbo oil return plate kills a few birds with one stone. We can now replace the factory block off plate with a billet piece that won't leak like the flimsy OEM formed metal piece. We also negate the need to tap and weld a fitting onto the factory oil pan, which can often be a PITA. :happy0180:
Old 08-29-2013, 01:04 PM   #14
King Tut
NASA SpecE30 Racer
King Tut's Avatar
From Ptuning
I know you are a Ptuning fan, but that won't work for 90% of turbo kits including the Greddy which is a front top mount.
