Old 08-25-2021, 11:20 PM   #1
FRBZGT
Drives: 2013 FRS
P1170 and P0171 after front pipe install
2013 Scion FRS
I recently replaced the front pipe from OEM to catless. I did literally nothing else besides that. After a ~5 minute drive the CEL popped up with P0171. I was a bit confused but reset it thinking it was a fluke. Drove two days without it coming back on and the car felt normal. Today it came back on again with P1170 added on to it. Car seems to idle a bit rough now.
I'm running a catless header and OFT but that has been on for over a year with no issues. It has a GrimmSpeed CAI but that has been on before I brought the car nearly 2 years ago. Those are the only mods outside of the front pipe.
I've tried searching but not much comes up. P117B seems to be a common code to go along with these two but I lack that.
FRBZGT is offline   Reply With Quote
Old 08-26-2021, 12:15 AM   #2
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by FRBZGT View Post
2013 Scion FRS
I suggest you take a log with your OFT and see why it thinks you're running lean. Or perhaps reflash your tune.
1974 TA22 Celica
2013 86 GT
Old 08-26-2021, 04:16 AM   #3
jason_456788
Drives: 2017 brz
I got the same issue it's because of the CAI. I put it back to stock intake with K&N drop in filter and problem solved. It's because the CAI with Catless you need a custom tune from OFT
Sent from my SM-N960U1 using Tapatalk
jason_456788 is offline   Reply With Quote
Old 08-26-2021, 07:05 AM   #4
Boccaccio
CAD monkey
Boccaccio's Avatar
Drives: '15 GT86 Giallo - Supercharged
Check your exhaust system for leaks. Pay particular attention to the header-overpipe and overpipe-frontpipe connection.
I suggest using a shop-vac with blowing function and soapy water:
Boccaccio is offline   Reply With Quote
Old 08-26-2021, 11:13 AM   #5
FRBZGT
Drives: 2013 FRS
LTFT is at ~39% which is bad right?
Old 08-26-2021, 11:27 AM   #6
jason_456788
Drives: 2017 brz
That's what I had... Also, my other experience was exhaust leaks between sensors. It would also make it at 39%
Old 08-26-2021, 05:01 PM   #7
p1l0t
p1l0t's Avatar
O2 sensor AND a vacuum leak... sounds like an exhaust leak to me.
Dzmitry (08-27-2021)
Old 08-30-2021, 10:25 PM   #8
FRBZGT
Drives: 2013 FRS
What do you know you are correct. Turns out a whole ass nut came off my header and another one was loose. Learned that you should invest in good tools and not just hope you got it tight enough. I still have a minor leak around the gasket but my fuel trims have returned to normal so I'm gonna call it good enough until this weekend.
The Following User Says Thank You to FRBZGT For This Useful Post:
p1l0t (08-30-2021)
CEL P0171, P1170, & P219A Feargt86 Software Tuning 3 03-02-2021 02:53 PM
Weird AFR and fuel trims P1170 P0171 Tonypepatone Issues | Warranty | Recalls / TSB 19 06-18-2019 08:20 PM
Check engine codes P0171, P1170, C1201, C1231, and c1241 HELP Crystalwhitebrzsti Issues | Warranty | Recalls / TSB 10 05-30-2019 06:45 AM
Odd idle and P0171 and P1170 codes dave- Engine, Exhaust, Transmission 0 09-26-2018 11:05 PM
Throwing P0171 and P1170 codes B-R-Z Software Tuning 39 01-27-2018 09:56 PM
