Old 08-19-2021, 05:47 PM   #1
Yetti
Drives: FRS
Custom Rom won't flash issue ECUTEK
Looking for help on an issue with flashing a custom ROM onto an ECU with ECUTEK. I was able to put the license onto the ECU and I am able to flash a stock ROM (ZA1JA00C or ZA1JB01C), although as soon as I make any kind of change to the ROM file, save it as another file and then try to flash that file onto the ECU as a custom ROM file I get the error shown in the picture.
"This ECU type can only be programmed with a standard ROM or......"
The custom file started off as a compatible ROM (ZA1JB01C) and the ECU will flash that file so I can't figure out why it won't take this one.
Any help appricated
Yetti is offline   Reply With Quote
Old 08-20-2021, 01:11 AM   #2
steve99
Any help appricated
if you modify a stock rom you cannot flash it with ecutek untill you add racerom patch
best to ise at least racerom 11.1 or higher
its easy to add jist add the patch version that matches your base rom ecu id
in your case ZA1JB01C
that way you also get the launch flat foot shift and auto blip features added thats the racerom patch
Old 08-20-2021, 09:14 AM   #3
Yetti
Drives: FRS
Thanks for the reply, I did not know.
The Following User Says Thank You to Yetti For This Useful Post:
steve99 (08-20-2021)
Old 08-21-2021, 06:24 AM   #4
gpvecchi
gpvecchi's Avatar
And adding RaceRom patch will mess up your Engine Load Limiter
gpvecchi is offline   Reply With Quote
Issue with HKS Flash Editor Kristian Software Tuning 5 03-16-2021 10:58 PM
OFT Flash purchase issue e_lunatic Southern California 3 12-22-2018 05:37 PM
Issue with HKS Flash editor Kristian User/Vendor/Sponsor Reviews, Feedback, Comments 5 04-28-2017 08:04 PM
Open flash issue gmanvilla1@gmail.com Software Tuning 30 07-16-2016 04:04 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 11:55 AM
