Old 07-04-2016, 02:11 PM   #1
gmanvilla1@gmail.com
gmanvilla1@gmail.com's Avatar
Drives: FRS
Open flash issue
Open flash tune: I haven been running corn fuel for approx 3000 miles an never had a problem. Two weeks ago I switch back my tune to the original for my free oil change at the dealer. I immediately went back to corn fuel and stage 2 EL tune but a couple day after the traction control light and check engine light came on. I drove the car for a couple of days and at times the car would lose power...I tuned the car back to the original time and both lights went away. I am hesitant of going back to E85 but sure miss the power. Is a 2015 with only 11k miles. Any thoughts?thx
gmanvilla1@gmail.com is offline   Reply With Quote
Old 07-04-2016, 02:15 PM   #2
Teseo
Drives: frs
What codes threw?
Old 07-04-2016, 02:20 PM   #3
Drives: FRS
Originally Posted by Teseo View Post
What codes threw?
Not sure what you mean...just the traction control and check engine lights came on and once loss power as I was on first gear. Got concern thinking it wasn't related to the open flash and reading articles of having to open the motor to address this issue I then decided to flash it back to the original tune to be able to take it to the dealer and when I concluded with the tune I realized both lights when off.
Old 07-04-2016, 02:40 PM   #4
Teseo
Drives: frs
Open flash tablet can read/clear codes, if you can read them, then report here for more help. Without them its just guessing
Old 07-04-2016, 03:05 PM   #5
cjd
cjd's Avatar
Drives: 2017 BRZ
Any codes?
Anything plugged into the odb port when this happened?
I had a similar issue with my 86Nanny plugged in, turned out to be a weird/bad batch of ODB connectors that made intermittent connection - every time it lost connection and regained it, it would try to handshake and sent the ECU into fits. Fixed the connector and no issues since. I should add, support was awesome -it could be anything not quite properly seated on the ODB causing this. Also, the code is important, just in case it's something else.
Old 07-04-2016, 06:11 PM   #6
steve99
Use your OFT (under diagnistics i think) to read out the check engine light (CEL) code is will be something like Pxxxx or Uxxxx. if you post up what the codes are we might be able to help
Old 07-04-2016, 09:08 PM   #7
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
A check engine light always has a code associated with it that gives you an idea of what the problem is (well, it gives you a place to start looking for a prob anyway). An OBD2 port reader or your OFT can read what this code is
Old 07-04-2016, 11:40 PM   #8
jerbull
Drives: 2013 FRS Asphalt
Post the codes. Also a log containing your fuel trims would be helpful.
jerbull is offline   Reply With Quote
Old 07-05-2016, 11:49 AM   #9
wparsons
wparsons's Avatar
Why did you flash back to stock for an oil change? They aren't going to plug into the OBD port for that, and even if they did they wouldn't have the tools at the dealership to compare the ROM on the computer to a stock ROM.
flickr
Old 07-05-2016, 03:45 PM   #10
Drives: FRS
Are you serious. I had no idea. I was under the impression they would find out. And the car was running incredible....I will flash it back in a couple of day when I fill up e85 and see how it goes.
Old 07-05-2016, 03:46 PM   #11
Drives: FRS
I will. Thank you.
Old 07-05-2016, 05:29 PM   #12
phrosty
Maybe he found the one proactive dealer in the world who likes updating customer cars .
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 07-05-2016, 07:07 PM   #13
steve99
Warning they can check the CVN (checksum value) with techstream/subaru ssm tool. This gives them enough to prove the rom in car is non standard. The CVN is available as a standard PID so can be pulled even on ecutek/brzedit locked tunes. And will catch you out even if you flash a "stock" rom with Ecutek due embedded licience info changing CVN.
With OFT or Tactrix you can flash back a 100% stock rom and CVN will match the stock rom calid CVN.
As stated its extremly unlikely thet they will check the CVN at standard service. as they have to look up the value of stock rom CVN, but its possible.
They would only usually check CVN if you had problems or maybe other obvious mods .
They usually plug in their diagnostic tool at any service to check for stored codes also not all fault codes the CEL light.
Old 07-06-2016, 01:56 PM   #14
Drives: FRS
Thank you sir. You da man
My experience with Shiv & his products at Open Flash Tablet / Open Flash Header TouchMyHonda User/Vendor/Sponsor Reviews, Feedback, Comments 5 10-23-2015 09:57 AM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 08:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 02:08 PM
Open Flash Tablet template issue BuBlake Software Tuning 3 10-13-2014 07:47 PM
