Old 08-17-2021, 04:20 PM   #1
Gamabouy
Drives: '14 Black GT86 AT
Post fix my suspension or tires first?
I have recently noticed that my car does not feel as planted as it once did, especially when going over forks or bends, the car felt squirrely and losing grip. I assumed it was because of the horrible Kumho tires on it that were 3 years old (they still have a lot of thread left). Even on u-turns with little throttle input I see the traction light flicker at times. The alignment is a bit off but not too bad and the problem AFAIK.
Also, the front end of the car makes a clunking noise whenever I go over a small bump with any speed above 10 kph, it feels as if it is hitting the steering column every time. I had this inspected at a shop and they said that the front sway bar linkages had cracked bushings all over along with a leaking bearing.
Below are pictures of the worn out bushings/bearings on the front and a leaking rear passenger side strut.
Initially I had planned on spending money on a nice set of Michelin PS4s to fix my handling issues but now I am wondering whether the issues arose because of that leaking rear shock and the worn out bushings up front.
What would be of the utmost importance to repair/replace first?
Gamabouy is offline   Reply With Quote
Old 08-17-2021, 06:46 PM   #2
norcalpb
norcalpb's Avatar
Suspension. If you do tires first you may prematurely wear them out because your suspension isn’t fixed.
The Following 2 Users Say Thank You to norcalpb For This Useful Post:
bcj (08-17-2021), soundman98 (08-17-2021)
Old 08-18-2021, 09:25 AM   #3
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Replace strut, everything else looks normal...
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following User Says Thank You to Opie For This Useful Post:
nathand (08-18-2021)
WTB: STX Suspension (Coilovers) and Wheels+Tires Optimoose20 Want-To-Buy Requests 0 08-25-2020 03:56 PM
New Tires With Air Suspension shadowking1711 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-24-2020 10:11 AM
Rubbing on OEM suspension and OEM tires fillthee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-29-2020 11:36 AM
FS: OEM suspension OEM wheels with tires funcheung Canada Classifieds 3 05-11-2017 10:57 PM
Suspension settings for different size tires Pokeguyjai Tracking / Autocross / HPDE / Drifting 2 01-24-2014 03:44 PM
