Old 08-15-2021, 06:11 PM   #1
Grisha
Grisha's Avatar
Drives: '13 FRS
Unhappy Front Suspension Clicks - Please help!
Howdy All,
I feel like I'm going insane because I cannot figure out for life the source of the clicking in my Front Left while:
1. Coming to a complete stop;
2. Making a turn/maneuvring into a parking spot at slow speeds.
I was able to replicate the clicking noise while having the suspension loaded, and turning the wheel. Here's the full video:
Timestamps: 1:30 - noise while turning; 2:25 - coming to a complete stop.
Things I've done:
1. Retorqued everything that connects to a coilover to spec - nothing was loose;
2. Replaced old end-links with Whiteline; torqued all nuts & set the preload.
3. Readjusted the preload;
4. Drove around for a week, and retorqued everything again.
A little background:
1. '13 FR-S with 115k miles, DD.
2. TEIN Flex Z coilovers installed @ 85,000.
3. Lowered ~1.5"
Thank you, everyone, for your feedback!
Grisha is offline   Reply With Quote
Old 08-21-2021, 07:31 PM   #2
Grisha
Grisha's Avatar
Drives: '13 FRS
Update: The clicking issue has been resolved! I got a helper and had him turn the wheel while taking a closer look while under the car. The noise was coming from either the top of the sway bar link or the coilover itself. I disconnected the link and inspected the ball joints; everything seemed to be normal.
Upon further inspection, I found that the lock collar on the coilover wasn't torqued to spec. Per this article -> http://teinusa-blog.com/torque-your-dampers-pt-1/:
The torque spec for the Seat Locks is 41.7 +/- 1.8 ft-lb.; The torque for the Lower Bracket Seat Lock differs between Strut and SA (Non-Strut) Dampers.
The torque spec for Strut Types range is from 101.2 to 115.7 (+/- 3.6) ft-lb.
The torque spec for SA Types is 50.7 +/- 1.8 ft-lb.
After re-torquing the collars and smashing my finger, I was able to get rid of the noise. Hopefully, this thread will help someone in the future!
Anybody “12-16 clicks” from full stiff? brandonleetran Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 11-04-2020 11:34 AM
Car clicks but won't crank. Battery or Starter? JERM^ Issues | Warranty | Recalls / TSB 93 09-14-2019 10:11 AM
Tein Street Advance Z - too many clicks for damper adjustment possible Nickmann Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 04-08-2019 03:10 PM
Rear Suspension Clunking, front suspension groaning Butterballz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-14-2018 07:10 PM
KW V3: 16 clicks for compression? h3opama Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-02-2015 08:01 PM
