Had a hard time seating new brake pads
I put in the new metal sheet metal things, and lubed the pad ears, and it was a real hassle to get the pads to seat in the notches. Is this normal? I had to jam the metal sheets with a screwdriver to make they were fully seated into the notch. Even still, the pads did not just slip into place easily.
ProCrastinationConsultant
what replacement pads did you use?
likely an issue with the specific company
#3 | |
Drives: 2016 Scion FRS Release Series 2#439
I resorted to cleaning up the original OEM clips which showed no wear and reusing them. The new pads went in easily then. Damn aftermarket crap! |
| The Following User Says Thank You to Muskoka800 For This Useful Post: | strat61caster (08-22-2021) |
#5 | |
There were none on Centric pads. |
| DIY - Changing Your Brake Pads (Race Pads upgrade) | PMok | DIY (Do-It-Yourself) Guides | 53 | 09-03-2021 05:17 PM |
| FS: OEM wheels, HAWK HPS front and rear brake pads, OEM brake pads, TYC colins tails | oppiee | Canada Classifieds | 4 | 10-07-2019 05:27 PM |
| Changing Brake Pads for the first time. | vincelive123 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 09-22-2016 10:26 PM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
| People having a hard time with the FR-S blind spot | driver01 | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 06-16-2012 03:27 PM |
