Old 08-13-2021, 08:55 PM   #1
daniloneil8
14mm top caliper slide pin is blocked by brake hose
Socket can't fit.
So, I used a 14mm flex head wrench.
What tool do you prefer to use to remove that top nut?
daniloneil8 is offline   Reply With Quote
The Following User Says Thank You to daniloneil8 For This Useful Post:
humfrz (08-14-2021)
Old 08-14-2021, 12:34 AM   #2
humfrz
Originally Posted by daniloneil8 View Post
Socket can't fit.
Bubba says whatever you can get in there and it fits the nut.
I remember, back in the day, I couldn't find a wrench that would access the adjusting nut on the side draft carbs of my 1970 MGB-GT.
So, I cut a wrench in half and it worked just fine.
soundman98 (08-14-2021)
Old 08-17-2021, 10:00 PM   #3
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
as a professional wrench, I see this shit each and every day. I am honestly not sure how these types of things get thru all the levels of authority they do before they are allowed to be built.
Just find whatever you can fit in there. Sometimes its a specialty tool, but other times its just swear a lot and figure it out.
So annoying when you are paid flat rate and something that normally takes 3-5 seconds takes 15 min.
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align.
Gruppe-S UEL header/overpipe
Wayne Rom Stg 2+ tune
225/45VR17 RT660s
JohnH is offline   Reply With Quote
Old 08-18-2021, 08:13 AM   #4
steverife
Drives: 2016 Scion FRS
I've got a couple of ratchets and I have to use the one with a smaller head, but I've never had a problem putting a socket on the that bolt.
steverife is offline   Reply With Quote
Old 08-23-2021, 09:58 PM   #5
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Looks like a regular socket fits just fine.
Maybe the brake line can be clocked differently ?
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Old 08-23-2021, 10:25 PM   #6
Ohio Enthusiast
Drives: 2018 BRZ
Fronts have okay access. Rears are the problem.
Ohio Enthusiast is offline   Reply With Quote
Brake Pad for Dual Caliper Hydro e Brake Katsu Tracking / Autocross / HPDE / Drifting 14 05-22-2020 02:52 AM
Stoptech S/S brake lines: same between stock caliper vs big brake kit? mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-10-2016 07:14 PM
F1 brake testing. Brake caliper porn! Captain Snooze Other Vehicles & General Automotive Discussions 11 10-16-2015 12:55 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
