Old 08-08-2021, 02:03 PM   #1
vokiller
vokiller's Avatar
Drives: White 2013 brz premium
engine code p0456
Can anyone help me fix this error
vokiller is offline   Reply With Quote
Old 08-08-2021, 02:56 PM   #2
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
engine code p0456
Check the gas cap
Evap error:
https://www.google.com/search?q=p045...ile-gws-wiz-hp
Old 08-08-2021, 03:31 PM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by Yoshoobaroo View Post
Haha... "Can anyone help me google this error?"
Old 08-08-2021, 04:04 PM   #4
Yoshoobaroo
TRACKBREAD
I felt passive aggressive enough to use LMGTFY but then decided to be nice
Old 08-08-2021, 05:30 PM   #5
Ultramaroon
not playing cards
so many feels
Old 08-08-2021, 07:19 PM   #6
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Last week an old guy brought in a CRV with EVAP leak codes.
I scan it, codes are not in active or pending, just in permanent, not wanting to diag the car for nothing, I touch nothing, clear the codes and run the EVAP self test. It passes, system is normal. I ask, and it turns out he messed with the fuel cap but when the light didn't turn off he brought it in thinking it was something else.
So my question to you is: What it your ideal outcome? You bring it in and pay 20 minutes of diag time + scan tool to be told it's your filler cap not tightened all the way, or you bring it in and pay 20 minutes diag time + scan tool to be told it WAS your filler cap and you brought it in for nothing.
I guess what I'm trying to say is, Very Small Leak is a 0.020" hole, be prepared to guess and wait. if you don't wanna, then don't touch it at all.
Old 08-17-2021, 11:51 PM   #7
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
evap codes can be a total bitch.
or they can be super simple.
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align.
Gruppe-S UEL header/overpipe
Wayne Rom Stg 2+ tune
225/45VR17 RT660s
JohnH is offline   Reply With Quote
Old 08-18-2021, 02:40 AM   #8
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Location says New Jersey, I'm guessing you never felt the texture of your own gas cap's cheap plastic before or even knew that it hangs on the gas door for convenience?
Is your check engine light currently on?
Go home, turn off the car, pop the gas door, take a deep breath, touch the gas cap and feel it. It's not going to hurt you. Unscrew it, then screw it back in and make sure it clicks in place. Now spend the next 200-300 miles driving your car at many different conditions: highway, city, hills, various weather conditions(temps), accel, decel, etc. If you're lucky enough to have triggered the car's self-monitoring system, and if it was just a gas cap tightening issue, then the light should go off.
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Engine Code P0366 eightsevenzero Issues | Warranty | Recalls / TSB 1 11-18-2018 12:41 AM
Code P0456 what gives? Andryuha Issues | Warranty | Recalls / TSB 8 05-22-2018 02:29 PM
HELP code P0102 engine goes on and off aldo29199 Engine, Exhaust, Transmission 5 07-26-2016 07:57 AM
CEL p0456 code, jerking when braking RedNWhite Issues | Warranty | Recalls / TSB 7 06-03-2016 06:35 PM
Engine code: P0617 OooDangMark Issues | Warranty | Recalls / TSB 3 05-22-2016 09:23 AM
