Old 08-04-2021, 07:36 PM   #1
Aaronberk21
Drives: 2013 Scion Fr-s
Unhappy FR-S Sync rings going out
I have had my 2013 FR-S for about six months now and it has about 109,000 miles on it now. The sync rings are starting to go out and I want to get them fixed but I cannot find anywhere that is willing to do it. I live in Arizona and every transmission shop I have called tells me they are "not comfortable working on that transmission." Does anybody know of any reputable shops which could rebuild or at least replace the synchros in my transmission?
Aaronberk21 is offline   Reply With Quote
Old 08-04-2021, 07:51 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Would probably be cheaper to source a used transmission. They run between 400-600 in my area.
What are the symptoms? What oil and when was the last change? Syncro issues are known, but a lot of times they can be helped a lot with better oil.
Old 08-04-2021, 08:32 PM   #3
Aaronberk21
The Main issue is shifting from third to fourth quickly and downshifting from sixth to fifth I get a bit of resistance and some serious grinding. For the transmission fluid it was changed at 101,000 miles (now at 109,000) and I am not sure what they used. Engine oil I use Mobil 1 0-20w extended performance and I changed it about 15 miles ago. What oil are you referring to and what would you recommend?
The Following User Says Thank You to Aaronberk21 For This Useful Post:
humfrz (08-05-2021)
Old 08-05-2021, 02:09 AM   #4
humfrz
Well, that's too bad your transmission is acting up -
I'll ring up our manual transmission expert ( @Ultramaroon ) for you. He may have some advice. He may not respond till tomorrow, he is getting a bit long in tooth and needs to get to bed early -
jcw99 (08-05-2021)
Old 08-05-2021, 11:35 AM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I use Redline MT-90 in the transmission. My car has had an issue if I shift quickly from 4th to 5th, I have just learned to be more deliberate with it. Try blipping down your shift from 6th to 5th and see if it is better.
Old 08-05-2021, 11:52 AM   #6
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
The transmission is based off the manual transmission that comes in the Toyota Tacoma's...any shop that can rebuild those, can rebuild these.
I suggest buying a rebuilt transmission from Atlanta Speed Company, it'll come with carbon synchronizers and they take your transmission as a core.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following 2 Users Say Thank You to Opie For This Useful Post:
Ultramaroon (08-05-2021), YamahaR86 (08-06-2021)
synchro issue, synchros, transmission grinding, transmission sound
Wing Mirrors Folding Sync Issue FRS2017 DIY (Do-It-Yourself) Guides 26 08-23-2018 01:36 AM
centering rings necessary? bakerr6 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 03-24-2014 03:46 PM
Switchbacks out of sync with rear signals? PantsDants Cosmetic Modification (Interior/Exterior/Lighting) 1 09-24-2013 02:17 AM
How to remove sync'd phones from headunit? ShoNUFF Electronics | Audio | NAV | Infotainment 3 01-09-2013 05:54 AM
how do you sync an iphone to the blue tooth in the car? pr086 Electronics | Audio | NAV | Infotainment 5 12-06-2012 09:51 AM
