Old 08-02-2021, 01:32 PM   #1
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
Foam Between Oil Pan and Cross Member
Hi all,
So while cleaning my engine bay from an oil leak, I discovered a piece of foam (pictured) between my oil pan and what I think is the transmission on the back side of the engine just above the cross member. It looks to be an OEM piece, as it's formed and was centered on the back of the pan, and may have (until being oil soaked) had an adhesive backing. Does anyone know what it is? I'm assuming to either catch fluids (in which case it worked wonderfully) or to soak up some form of vibrations.
If anyone knows what it is, I'd like to replace it. I haven't found the part number or if anyone has an idea of where to acquire another/more, I would appreciate the help.
Image 1: the foam off my car
Image 2: circled where it was, image from Google.
villainous_frx is offline   Reply With Quote
The Following User Says Thank You to villainous_frx For This Useful Post:
Ultramaroon (08-02-2021)
Old 08-02-2021, 02:12 PM   #2
Joon525
Joon525's Avatar
Drives: 2016 BRZ
It gets stuck to the metal inspection cover that bolts up to the back of the block just under the flywheel.
https://estore.subarupartswarehouse....BoCf3IQAvD_BwE
Joon525 is offline   Reply With Quote
The Following 3 Users Say Thank You to Joon525 For This Useful Post:
jrhudson (08-03-2021), Ultramaroon (08-02-2021), villainous_frx (08-02-2021)
Old 08-02-2021, 02:25 PM   #3
villainous_frx
Off to the track!
Sweet! Calling Toyota today and this will be added to the list. I really appreciate it, I stink at navigating the online parts diagrams.
Toyota PN appears to be SU00300129 (https://parts.toyota.com/p/69381895/SU00300129.html)
Old 08-03-2021, 05:04 PM   #4
jrhudson
Drives: 2016 scion frs
Man when i saw foam. I thought about bubbles and soap lol.
I happen to be putting on my oil pan stuff on and i took a picture of that plate thing.
I only remember 3 strips of foam. I just ordered off of amazon. Since its just some foam you place on there
jrhudson is offline   Reply With Quote
Replacing front cross-member without taking engine out RapidEntropy Engine, Exhaust, Transmission 7 07-14-2020 05:45 AM
Perrin 3" CBE - S Pipe / cross member clearance? 1Cor10:23 Engine, Exhaust, Transmission 0 05-21-2014 03:06 PM
Cross member bushings vs. Inserts wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 11-22-2012 03:40 PM
Foam guns sa1126 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 11-07-2012 11:01 PM
Foam Gun: Necessary? Re~Mix Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 15 06-24-2012 11:45 PM
