Drives: 2013 GT86 Limited
Replacing front cross-member without taking engine out
I noticed that my front left wheel is set back by almost 2 centimeters, and inspected the front suspension.
Looks like my front cross-member is bent where it connects to the control arm, and i'm looking to replace them both but i am unsure if this could be replaced without taking out the engine. Does anyone know if i could jack up the engine by a bit, undo the engine mounts from the subframe ( keep them attached to the engine ) and replace the cross-member? Is there enough space to get it out? |
Drives: 2017 toyota 86
Should be able to don’t see why you couldn’t. May want an engine hoist instead of jack for safety.
If you want any other pics let me know. My cars always under the knife, luckily for elective surgery.
Señor Member
I suspect it would be one of those things where you'd do so much extra work to avoid taking the engine out that you should have just taken the engine out in the first place.
1974 TA22 Celica
2013 86 GT |
ProCrastinationConsultant
i'd be much more concerned with the forces involved and what else was affected than just the replacement of a single piece. crossmembers don't just bend with a small pothole...
There’s really not too much to getting the cross member out. Should be able to undo engine mount nuts from cross member, support engine, undo bolt for swaybar to end link each side, undo 4 bolts each side on frame mount brackets drop sway bar assembly, remove nut/bolt from lower suspension arm assembly on both sides, and then remove the 4 bolts from cross member assembly and drop cross member.
I wouldn’t trust working around a jack with engine overhead (especially with cross member out) if no access to hoist I would jack car up 2” after remove mount nuts put something real stable,sturdy, and solid under oil pan to support it and slowly drop csr back down on stands. Should get engine off mounts without using jack. Also as mentioned would be odd to have that be the only failure/issue. Also full disclaimer I haven’t done this. But looking around under there it really doesn’t look to hard. |
Drives: 2013 Subaru BRZ / 2011 Lexus ISF
Support the engine with a engine support bar and then drop the cross member.
Thanks for the replies!
I agree that using a jack isn't the safest option, i'll look into using a hoist to lift and hold the engine. The previous owner won't tell exactly what he did with the car but my best guess is he hit a curb straight on, and probably did a cheap repair by not fixing everything. As far as other bent parts, i checked some diagrams and it seems that the Suspension Control Arm Retainer allows for some play since it's able to rotate around where it is bolted on. I will replace the subframe, control arm, retainer and frame piece as i think those could all be slightly bent. See 50515B for the frame piece: ![]() See 20216 for the Suspension Control Arm Retainer:
| PSA: Replacing Engine Mounts can be a BITCH and much more! | Sportsguy83 | Engine, Exhaust, Transmission | 51 | 02-19-2019 04:40 PM |
| she's dead Jim. (Taking apart my engine to the crank) What would you do? | PitViper | Engine, Exhaust, Transmission | 25 | 09-23-2016 04:27 PM |
| FS: Cusco Power Brace Front, Rear, Rear-side Member and Engine Room | fungus | Canada Classifieds | 2 | 05-20-2016 11:36 AM |
| Perrin 3" CBE - S Pipe / cross member clearance? | 1Cor10:23 | Engine, Exhaust, Transmission | 0 | 05-21-2014 02:06 PM |
| Cross member bushings vs. Inserts | wootwoot | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 11-22-2012 02:40 PM |
