Grinding sound at low RPMs and during quick deceleration (even in neutral)
Hi, I bought my FRS 3 months ago with 92K miles on it. It’s been a while since I’ve driven manual so I couldn’t test drive it very well as I was too focused on trying not to stall the car (which I did 4 times during the test drive anyway). But eventually I got the hang of not stalling but I noticed whenever I started driving from a stop there would be a grinding sound. I assumed that I was using the clutch wrong and when I asked the previous owner about the sound he said “the cars have weak synchros and that sound is normal”
But the sound has gotten worse It used to be whenever I would start out driving (typically after sitting for a while) I would hear this grinding sound for about the half second spent at 1000rpms while gaining speed. But now the sound seems to stick around between 900-1500 rpms and is much more prevalent. It doesn’t make the sound at higher speed or higher gearing or at least I cannot recreate the sound in those conditions. Another thing is a similar, yet quicker fainter noise is made when I decelerate quickly, doesn’t matter if I am coming from 25MPH or 80MPH if I decelerate to a crawl or stop very quickly the sound will happen for a short instance I don’t think it’s worn synchros because I have no issues getting into gear or staying in gear and to the best of my knowledge the car drives like usual. But I’m almost certain the sound comes from the transmission because that’s about where I hear it, could be further up so I’m making my best guess. If anyone knows or has experience please help, thank you EDIT: I forgot to mention! The sound has started continually happening while driving at lower rpms, driving at about 10-20MPH the sound is not as aggressive as it is when starting out driving but still there and quite obvious |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
welcome - the twins are known for having many mechanical & agricultural sounds emanating from them. could be clutch or heat shield rattle which are common, but think we need a proper vid to hear what you're hearing..
and for your piece of mind, worn synchros are not common issues especially in regards to stock power...the throwout bearing on the other hand is really the main point of weakness for the manual trans. |
| The Following User Says Thank You to HKz For This Useful Post: | JesseG (07-29-2021) |
#4 | |
#5 | |
And I bought it from a dealer not from him so he doesn’t really gain anything if he was lying |
#6 | |
Your symptoms as described really point to a TOB issue to me.
He said it was done at the Subaru dealership however when I first got this car I didn’t know stick that well but still drove it hard (at first) could shitty driving lead to accelerated wear the TOB?
You would REALLY have to beat on it.
| The Following User Says Thank You to Tcoat For This Useful Post: | JesseG (07-29-2021) |
Reformed
when my TOB started to go out, mine would start squealing and the clutch pedal felt a little crunchy. I didn't get any sounds that I would describe as "rattling" or "grinding".. if they replaced the TOB and even if put the wrong grease in there it should still last much more than 15 K miles even if you aren't a great at MT. video!
#10 | |
Drives: 2016 Scion FR-S
It took me quite a while to get used to all the sounds. ![]() You hear basically everything the car is doing, whether you want to hear it or not. That personality is what makes me love the twins so much though. I hope the 2nd gen hasn’t removed all of that. I would be ok with a little quieter. I think it will be perfect, and just the right balance. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to JesseG For This Useful Post: | HKz (07-29-2021) |
#11 | |
Reformed
#12 |
I'd suggest you find another car like that (at a dealer or a car meet) and take that car for a spin so you will have a basis of comparison.
#13 |
LMGTFY
Drives: 13 FRS, 91 Miata
If the work was done at a dealership. Call and ask if the work was actually done or the PO is FOS.
#14 |
not playing cards
Normal gearbox rattle. Post a clip of the sound but I bet it's fine.
| Grinding noise in neutral | WGMGR | Issues | Warranty | Recalls / TSB | 28 | 04-12-2018 02:22 AM |
| buzz / rattles between certain RPMs during quick acceleration | howareyoukk | Issues | Warranty | Recalls / TSB | 47 | 01-25-2018 04:34 PM |
| Grinding noise at low rpms | Terruko | Issues | Warranty | Recalls / TSB | 6 | 07-17-2017 03:16 PM |
| Engine tapping sound on deceleration | qtwre | Engine, Exhaust, Transmission | 5 | 05-09-2016 03:52 PM |
| Neutral to 1st clunking sound | wallace03 | Issues | Warranty | Recalls / TSB | 3 | 01-10-2013 09:50 PM |
