Old 07-25-2021, 03:03 AM   #1
Bashyz
Drives: GT86
RPM NEEDLE NOT WORKING & U0100 + U0122 CODES
After following exactly the instructions for the installation of the magna gauge face on an automatic 2019 GT86, I started up the car and the needles were all misaligned, even though I did not move them at all and reinstalled them exactly the same. Whatever I did triggered the U0100 & U0122 codes and the RPM needle does not work, along with a hesitant startup + car dies. Moving the other needles back into place gets them to read correctly, but the RPM needle does not work at all. Thanks for any help guys
Bashyz is offline   Reply With Quote
Old 07-25-2021, 03:04 AM   #2
Bashyz
Drives: GT86
I should also add that I tried disconnecting the battery in an attempt to reset it with no luck.
Old 07-25-2021, 08:40 AM   #3
p1l0t
p1l0t's Avatar
Maybe you should undo what you did.
Old 07-25-2021, 06:23 PM   #4
ls1ac
ls1ac's Avatar
codes are for loss of communication. check plugs and confirm proper part numbers.
Old 07-26-2021, 06:51 PM   #5
Bashyz
Drives: GT86
the magna gauge face cluster is literally just a piece of paper that swaps out the OEM one for a different look. It is purely an aesthetic mod. The removal of the needles in the cluster was required to fit it and reinstallation was what misaligned the needle. Now I am not sure how to find the point to realign the needles
gauge cluster, malfunction, rpm needle, u0100, u0122
P0700 and U0100 Spacepeanut34 Software Tuning 6 01-16-2025 02:03 AM
Weird Issue u0100 u0122 Riftur Software Tuning 29 02-17-2020 08:09 AM
Need help. Video and codes P2271, P0171, C1201, U0100 voidn0ise Issues | Warranty | Recalls / TSB 8 05-03-2017 06:58 PM
DTC Codes U0122 and U0131 pleong Electronics | Audio | NAV | Infotainment 1 09-03-2014 02:40 AM
Gas needle not pointing to full SF-FRS Issues | Warranty | Recalls / TSB 11 10-05-2012 11:00 PM
