Old 10-04-2012, 07:27 PM   #1
SF-FRS
Drives: 2013 Scion FRS
Gas needle not pointing to full
I just went to the gas station and topped off the gas tank.....But when I went to start the car....it wasn't showing full....Hmmm
SF-FRS is offline   Reply With Quote
Old 10-04-2012, 07:29 PM   #2
einzlr
Drives: several
Gas gauges do that; they're not precision instruments. Don't even worry about it
einzlr is offline   Reply With Quote
Old 10-04-2012, 09:46 PM   #3
roddy
roddy's Avatar
Drives: '13 Ultramarine
I think I know what you are talking about. This has happened to me a few times as well. Every once in a while, when I fill the car, the needle stops about a needle's width short of full. The first time it happened, I made it a few blocks, and thought WTF? I pulled into the next gas station and managed to pump about 30 cents worth into it.
Old 10-04-2012, 10:07 PM   #4
fistpoint
Drives: Supercharged Golf Cart
Several people have mentioned this for this car. I think I prefer the Honda method which is often erroneous too. In their case it reads full for the first 3 gallons of usage then drops off significantly. I remember in my older Si's that I would make it a game to get as many miles as possible before the needle moved. Just over 100 is my record which is almost 1/3rd of the tank.
fistpoint is offline   Reply With Quote
Old 10-04-2012, 10:20 PM   #5
MmmHamSandwich
You know you want it.
MmmHamSandwich's Avatar
Drives: '13 FR-S
Hahaha. Fellow Si owner here. Definitely one of the quirks of the car. New drivers think "wow, this car gets great mileage, I haven't used any gas!".
The next thing you know you're at half a tank.
The Following User _________ Stay_Puft(09-13-2014)
Says Thank You to
MmmHamSandwich For
This Useful Post:
MmmHamSandwich is offline   Reply With Quote
Old 10-04-2012, 10:21 PM   #6
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
This is an issue I have quite frequently, I'll put a full tank and it only goes up to 3/4.
Spartan65 is offline   Reply With Quote
Old 10-05-2012, 02:23 AM   #7
Lithandril
Drives: Asphalt fr-s 6mt
I was thinking that too while i was driving around tonight. Drove over 100km and needle barely moved until i turned the car off lol
Lithandril is offline   Reply With Quote
Old 10-05-2012, 10:45 AM   #8
FR-S Hot Lava
FR-S Hot Lava's Avatar
Drives: FR-S Hot Lava (AT)
I had this happen to me also for about 6 fill ups would not go past 3/4 mark. then one day while driving around the gas gauge moved to full mark and knock on wood , so far after 3 fill ups seems to be working fine now when I go and fuel up.
FR-S Hot Lava is offline   Reply With Quote
Old 10-05-2012, 10:58 AM   #9
soconfoozed
Drives: 2013 BRZ Limited 6MT WR Blue Pearl
Call Subaru customer service instead. They'll tell you to go to the gas station. I don't know what I would do without those guys.
soconfoozed is offline   Reply With Quote
Old 10-05-2012, 03:22 PM   #10
SF-FRS
Good to hear I'm not alone....
Old 10-05-2012, 04:14 PM   #11
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
This is just how the Denso or the fuel tank manufacturer (I forgot their name) designed it. My current car is also like this. It takes a few minutes or so after refueling to get an accurate reading and sometimes when you're on a hill or something, it can be a little off. So yeah, annoying but I'm pretty sure that's just how it is so there's no sense demanding a fix.
Edit: I suppose this may not be the same issue if it never goes past 3/4 tank... In which case, that is a bit strange. All the more reason I wish it had a digital miles until empty display.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 10-05-2012, 10:00 PM   #12
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
I have seen this once when I only filled up to full with <10 litres!
smbrm is offline   Reply With Quote
0W-20 full synthetic oil for $3.49 a quart terrypm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 26 04-08-2014 04:51 PM
Help finding thread about startup rpm needle Prava Electronics | Audio | NAV | Infotainment 2 07-01-2012 01:29 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
Autoexpress full review Sport-Tech BRZ First-Gen (2012+) — General Topics 13 03-26-2012 08:56 PM
Anyone else paying in cash/full? iff2mastamatt Scion FR-S / Toyota 86 GT86 General Forum 46 03-23-2012 03:14 PM
