Drives: '18 WRB BRZ Limited w/ PP
Is stock battery AGM or wet?
Hello,
My stock battery is about done and almost three years old. Is the stock unit AGM? Any harm in going AGM other than wallet pain? |
Drives: 2014 scion frs
Stock battery is a unsealed, lead acid type. Absorbent Glass Mat (AGM) is a sealed battery which uses fiberglass to hold the electrolyte like a sponge. AGM batteries can be mounted in any position and are lighter than their lead acid counterparts. No problem using an automotive AGM but if you use a battery maintainer or charger, it will have to be compatible with an AGM battery.
Back in the day, I changed the battery in my old car and watched my jeans slowly dissolve over the next week. Last edited by 7 skulls; 07-07-2021 at 07:22 AM. |
not playing cards
Stock battery is not sealed. It is a traditional lead-acid wet battery that requires maintenance. Info in the owner's manual.
| The Following User Says Thank You to 7 skulls For This Useful Post: | Ultramaroon (07-07-2021) |
| Lightweight battery that fits the stock tray and tie down? | SPCorBUST | Engine, Exhaust, Transmission | 40 | 01-11-2021 10:46 PM |
| Specs of the STOCK battery?? | stevo_12v | Electronics | Audio | NAV | Infotainment | 74 | 10-31-2017 04:45 AM |
| Is the stock OEM Panasonic battery 55D23L rechargeable? | ghostzfh | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 57 | 03-15-2017 12:33 PM |
| How long does stock battery last without engine on? | jon2 | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 03-15-2015 09:58 PM |
| Warning to Canadian owners about stock battery | Suberman | CANADA | 46 | 03-02-2015 07:28 PM |
