Old 02-09-2017, 09:24 PM   #1
ghostzfh
Drives: 2016 Scion FRS Halo
Is the stock OEM Panasonic battery 55D23L rechargeable?
My battery is completely discharged from not driving my car often.
I'm looking at the stock FRS OEM battery and it says on the label, "Do not charge or use booster cables or adjust post connections without proper instruction and training".
I thought wet/flooded batteries can be recharged. I looked everywhere and can not find an answer to this. Is there anyone out there whose stock OEM battery died on them and if so, what did you do? Have you tried recharging the battery and if so, what happened?
ghostzfh is offline   Reply With Quote
Old 02-09-2017, 09:54 PM   #2
T-Steve
Drives: 2014 BRZ
Yes of course you can charge them. Mine was dead when I bought the car on the lot. The dealer charged it awhile and it was good for three years.
Then I didn't drive the car for a few weeks and the battery got pretty low, so I put it onto a trickle charger/battery maintainer. It brought it back up and it is great now.
T-Steve is offline   Reply With Quote
Old 02-09-2017, 09:59 PM   #3
ghostzfh
Was yours the stock OEM Panasonic that came with the car though? Why would Panasonic put a label stating it shouldn't be charged? I thought it might be dangerous to charge it.
Old 02-09-2017, 10:45 PM   #4
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Um, see bolded part...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 02-09-2017, 11:04 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
It's just a disclaimer to protect against litigious assholes. Nothing special about the battery.
Old 02-10-2017, 08:25 AM   #6
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Yup, what ^ he said
Old 02-10-2017, 08:49 AM   #7
stevesnj
stevesnj's Avatar
Remove terminal cables and put on 2amp charge. Done
My 2016 Build thread
Old 02-10-2017, 08:57 PM   #8
humfrz
First off, you might consider investing in a battery tender, if you go for long periods of time without driving the car. Make sure the electrolyte level is covering the plates. Add DISTILLED or DEIONIZED water if necessary.
Secondly, I'd suggest that you have your car's battery "load tested" at an auto shop ...... just to make sure it is up to speed (will hold a charge).
The cautionary warning has been discussed.....
(after messing with the battery, DO NOT wipe your hands on your pants or scratch your crotch)
humfrz
Old 02-10-2017, 09:13 PM   #9
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
I love this forum.
Old 02-10-2017, 09:55 PM   #10
ghostzfh
I don't know why, but I glossed over that on accident. I'm running the "Battery Tender" as we speak.
Old 02-11-2017, 06:45 PM   #11
Euro7R
Drives: 2013 Subaru BRZ
I charge mines every month. My daily trips are too short, doesn't charge the battery, so it's always weak.
Euro7R is offline   Reply With Quote
Old 02-12-2017, 08:52 AM   #12
WNDSRFR
Drives: FR-S,GTI
I replaced my OEM battery with a AGM battery when the car was new. After about a year of sitting in the garage, I attempted to use the OEM battery for something else. It was COMPLETELY dead. Zero volts. I hooked it to a charger and it just plain would not take a charge.
Rather than throw it away, after all this was a brand new battery, this is what I did:
I connected it in parallel to a bank of batteries I used for a UPS. The UPS is connected to a trickle charger. After about a month, I checked the battery in question and it was fully charged. It had come back from the dead. Two years later and it's still good (in my VW).
Old 02-12-2017, 01:40 PM   #13
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
I got myself a smart charger. If i am going out of town for a week. I would pull my OE battery out and charge it. The car is 3 and half year old and it is still fine.
Muaddib is offline   Reply With Quote
Old 02-12-2017, 10:26 PM   #14
Ultramaroon
not playing cards
Just curious, do you pull the battery because you can't park closely enough to an outlet? If so, I sincerely applaud your dedication.
battery, oem, panasonic, rechargeable, stock
Specs of the STOCK battery?? stevo_12v Electronics | Audio | NAV | Infotainment 74 10-31-2017 04:45 AM
How long does stock battery last without engine on? jon2 Scion FR-S / Toyota 86 GT86 General Forum 15 03-15-2015 09:58 PM
Warning to Canadian owners about stock battery Suberman CANADA 46 03-02-2015 07:28 PM
Panasonic audio/nav switches itself off in the cold! Suberman Electronics | Audio | NAV | Infotainment 0 12-05-2013 08:01 PM
